Question about Kohler Electrical Supplies
UNDER A LOAD POWERS OFF
GENI. RUNS FIN THEN WHEH A LOAD IS PUT ON IT DIES. CARB. HAS BEEN CLEANED I THINK. BEEN LIKE THIS FOR THREE YEARS.
  • 66 Answers
SOURCE: 2003 yzf450 wont run right?
recheck pilot jet & pilot circuit.also check compression
Posted on Feb 16, 2009
cape cod bob
  • 292 Answers
SOURCE: bike runs at Idle but dies when given gas
have you changed the fuel filter? you are not getting enough gas, are jets squeaky clean? there is a good fuel system cleaner in the USA called Berrymans B12. put some in the tank warm up bike then let it stand overnight and see what happens. if still no luck repeat process. if you still have same problem then get new fuel filter
good luck
Posted on Apr 02, 2009
robotek
  • 1512 Answers
SOURCE: 350 raptor only runs with full choke on ,
Hi Mike,
You will find that there is a problem with the carbie. It runs with the choke on because the choke engages the "enricher" circuit. The idle circuit is different a different circuit inside the carb. When just crack the throttle on, you use the pilot circuit, and then main jet with more twist of the grip. You will need to completely strip the carb, remove all jets, spray carbie cleaner throughout, and blow out all capillary tubes and holes inside the carb with compressed air. Pay particular attention to the fine holes inside the venturi near the butterfly valve. You may need to use a fine piece of wire, like a guitar string to open up any that are clogged.
There is not much else that will cause the symptoms you have. Check for air leaks about the inlet manifold also, spray some carbie cleaner about the manifold connections boots, the revs will change when it sucks up the cleaner through the leak.
Happy to talk to you more about it.
regards robotek
Posted on Jan 24, 2010
SOURCE: Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Posted on Jun 08, 2010
  • 1383 Answers
SOURCE: em 5000sx runs but stalls under load
GX340 engine always works best with complete carb kit that at least contains main jet, needle valve, main nozzle and orings. It is hard to clean varnish/crud from carb and soaking may make it worse. Kit is not expensive. Check ebay, less than $10. Before you change any parts make sure that your cap is venting properly. Many California gas caps (tall chrome gas cap) may cause fuel lock. Also check that muffler is not restricted with carbon. Good luck
Posted on Jul 10, 2010
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
My tractor dies when I put it in gear.
solenoid only engages the starter nothing else .it could just need the carb cleaned
Apr 16, 2016 | Garden
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
FC540v Kawasaki john Deere 265, bugs down under load,emitting black smoke & then dies. Works fine without air filter.Carb cleaned, Compression check has 80 lbs
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Thanks for your attention to this matter.
Aug 29, 2012 | Cars & Trucks
Honda GC 160 Engine, I had the carb replaced about 1 year ago, now its doing the same thing. At first it wouldnt start at all, I cleaned the carb, then it started would speed up and die. I then took the...
This really sounds like a carb problem, good to hear that you are taking the carb all the way off and soaking it, this is the best way to clean a carb. I don't think it would be the fuel pump, they either work or they don't. I would check the governer springs and linkages, if one of these is hung up on something it would cause the problems the you have identified. Also, when you re-install the carb make sure that you have all the gaskets installed, it is easy to forget one and that will cause the engine to **** air and make the whole engine run like ****.
Oct 21, 2010 | Karcher 2500 PSI Pressure Washer
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Electrical Supplies Logo
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
