Question about Birds
Black with red patch on trout - Birds
A black head small Australian bird with a white patch on both sides of its head with a red beak
check the bird identification pictures but it sould like a black head finch
Mar 10, 2017 | Cars & Trucks
PS2 shows a black screen with a red cross through it at a certain point after starting a game. Won't let me advance past this point. What does this mean and how do I get game working?? It has worked before...
It sounds like you have a modded PS2. You may have to find a patch in order for the game to progress (probably has some sort of copyright protection). You should be able to search the web to see if you can locate a patch. Type in something like PS2 modded and the name of the game.
Jun 24, 2014 | Video Game Consoles & Games
When I'm stoped and i push in the clutch it still go like it is in 1st gear i have replaced the slave cylinder, clutch and clutch master cylinder.
did you adjust the clutch pedal for proper gap between the preasure plate and troutt bearing. this could be that the clutch is not pushing in trout bear far enough to release and spin free. you can check how far the trout bearing is form the fingures of the preasure plate by removing trans. view plate next to the clutch cyl. I believe it is 1/8 inch gag. you have to eyeball it. Another way of telling if trout bearing is still engaged. when you are in nutrual you can hear its spinnig with a med. sound. of a hum or if you had this issue for a long time you really will hear it.
Nov 22, 2010 | 1991 Isuzu Rodeo
My Sony Bravia's screen is showing images in red and black only. By playing with the input sockets at the back (pulling out the leads and reinserting) it was temporarily fixed the problem but, now it seems...
If you are using Component Input (green/blue/red inputs) with component patch cords, try using other input jacks ( Video In (yellow) or Cable/RF In). If the color is good, then replace your Component patch cord, the green one is broken.
Aug 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Pccharge invalid trout id number
It sounds like your TroutD has somehow gotten out of synch with the last processed transactions. Usually, you can go to setup -> numbers and synchronize the TroutD to the last number used. This will usually correct the issue.
Jul 03, 2009 | VeriFone PCCharge Pro Full Version for PC
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Red patches in black areas and halos in bright areas
If you adjust the brightness or contrast does the "bleeding " get less or more apparent. This sounds like a high voltage problem that used to occur in CRT's.
Dec 22, 2008 | Televison & Video
When I turn on the TV, the white has flickering patches of teal and black has flicker patches of red. In fact, almost 3/4 of the white is covered in teal and the black has about 1/3-1/2. I am using a...
It seems as though you are using the component video inputs. If you are then more than likely you have bad connections between your peripherals(dvd, xbox, etc.) and your TV. Just make sure that all the connections are tight/pushed on to the terminals all the way and that you don't have bad cables.
Dec 11, 2008 | Insignia 37" LCD Flat-Panel HDTV
Dvd player chdvd300
what type of output r u using on the dvd player, component, svideo, or the patch cord yellow, red and white..,
Nov 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Birds Logo
66 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
