Question about Yamaha YSP-800 System
Why is there no power to my ysp-600 sound bar
Have changed the fuse and can't seem to switch on the sound bar
Why wont power come back on the unit all the fuses are good
Never use a staple on a power wire.
Remove the staple and check for damage within the sound bar.
Feb 27, 2017 | Denon Audio Players & Recorders
My sound bar itb382b switches sources on its own. Any idea why it won't stay on source we choose?
if you are using a remote that is the same or similar to the brand name of your sound bar then particular buttons my trigger your sound bar to change devices for example when you change the channel on your TV with your TV remote it might trigger your sound bar to change as well. this is common for infrared receivers
I’m happy to help further over the phone at https://www.6ya.com/expert/patrick_a6ad75ecfd3c3891
Dec 08, 2014 | iLive ITB382B - 37" Bluetooth Sound Bar
Don't know what to check next.If unit is bad horn would still work I would think.Tell me what to check next.changed circuit breaker.
Need more info to help you with your issue what year and type of vehicle and the issue is that the horn don't sound
Nov 12, 2014 | Cars & Trucks
95 honda shadow 1100 wont crank
There is one more fuse near the battery, check the starter switch on the handle bar if you have 12V coming in to the switch.
Jul 28, 2013 | 1995 Honda VT 1100 C Shadow Spirit
Beater bar not working - no variable suction
Take it to your local vac shop for repair. Depending on what model you have, it may have a bad switch or you brushroll ends could have failed. Both are common issues.
Aug 08, 2017 | Dyson Vacuums
Horn tail light and blinkers wont work
Check the fuses ...sounds like you may have fried one or two, Also that is a very tight fit where the brake light switch is....make sure you are not grounding out in the bars where the switch fits in the groove
Jan 11, 2013 | Harley Davidson XL Sportster 883...
Brake lights don't work
This sounds like a bad brake light switch, this switch is located on the bracket that holds brake pedal,you can test for power at switch,also if you remove connector and jump terminals with a wire and see if lights lite, if lights light then switch is bad,
May 27, 2010 | 2006 Hyundai Sonata
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Yamaha YSP-800 System Logo
131 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
