Washing Machines Logo
Posted on Jun 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can some one help me??? My washer won't a gitate properly I don't know if a part is mising I don't see the cam & dogs that suppose to be there. Its a very old washer. Please I need help?????
Mike Price
Level 3:
President:
  • Master 744 Answers
  • Posted on Jun 23, 2009
Mike Price
Master
Level 3:
President:
Answers
744
Questions
5
Helped
243564
Points
2874
You need to replace the dogs, I have included a link with a diagram which should help. You can get the parts from www.repairclinic.com
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?&&model_id=502846&diagram_id=122646&NewWindow=1
Hope this helps :)
  • Mike Price
    Mike Price Jun 23, 2009
    I forgot to mention the part you need is #10 on the diagram.
What's the cause of my washer's agitation and noise problem?
Possibly a bad basket drive. Or something is wrapped around the shaft under the tub or something is in the pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Top agitator, not being spun by motor
If the problem is just the the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. Please include a complete MODEL NUMBER with any questions you may have. I hope this is helpful to you.
1helpful
Agitator problems..
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
Thank you for posting your model number. The part numbers you may need are as follows:
Item 10 - If just replacing the Agitator Dogs: 80040.
Item 9 - If replacing the entire Cam Assembly: 285809 (includes the Dogs and the Cam Thrust Bearing).
Item 22 - Spacer Thrust Bearing: 3951608
All these parts can be viewed under the "Agitator, Basket and Tub Parts" section of the parts resource websites I listed for you. The last digit of your model number is a "zero" (0), vice the letter "O".
If you have any questions, please post back and let me know. I hope this is helpful to you.
2helpful
Agitator is not agitating. Cant seem to get
If this is a Whirlpool manufactured TOP LOADER, and this is a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
If you have any questions, please post back and let me know. I hope this helps you.
2answers
Auger in top load washer don't turn when in washing cycle but does spin in spinning cycle
This sounds like a problem with the agitator. Or the drive for the agitator. If you can hear the motor running but do not have any agitation then something in the agitator may be stripped. If not then you may have a timer or electrical problem. Let me know if I can help in any other way.
Ken
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 16, 2009 • Dishwashers
1helpful
Agitator seems to be loose It does not seem to agitate like it is suppose to.
Your problem may just be attributed to just a loose agitator bolt, or the agitator dogs require replacement.
Roper (which is manufactured by Whirlpool) has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is 285811 and sells for about $11.
1helpful
The agitator does not rotate properly, at least not
This problem is commonly caused by worn dogs on the agitator cam. The following link explains what agitator dogs are and how to replace them:
The agitator in Whirlpool manufactured washers has a split design. The upper portion (called the auger) has a small cam under it that commonly wears out with age. This can cause the auger to slip or not spin at all.
This is a very simple and inexpensive repair. The part number is included in the link I provided. Replacement dogs can be found at appliancepartspros.com for about $5. For a little more, the entire cam replacement kit can also be purchased for about $10-$11. The kit includes the cam, bearings, washers and the dogs.
Can some one help me??? My washer won't agitate
the model number would help me out in answering this question, feel free to call our free tech support and order parts from www.whirlpoolpartssurplus.com
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
