Question about Kyocera Mita KM-2050 Printer
How to fix c6050 - Kyocera Mita KM-2050 Printer
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 245 Answers
My dear press10871087 after press 163 reast
Posted on Dec 24, 2014
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera C6050 error
C6050 Error
Abnormally low fusing unit thermistor temperature
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset
Jul 03, 2014 | Kyocera Office Equipment & Supplies
Kyocera 2520 error c6050
it happen because there is problem with termostat of the heater unit
change that thermostat or connect the tow wires with each other
Sep 02, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
C6400
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine.
Enter the maintenance item number (163) using the up/down keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Turning power switch off and back on
Description
Purpose
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera Copystar CS-1820 Black and White...
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
Error: Call Service Code: C6050
try to press code 10871087 then 163 and lastly press clear/stop button for a while.
Nov 17, 2008 | Copystar CS-1620 Copier
Sytem error C6050
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Jan 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera Mita KM-2050 Printer Logo
57 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
