Question about Toshiba 46HM95 46" HDTV
I have toshiba 46HM95 buzzing noise - Toshiba 46HM95 46" HDTV
3 Suggested Answers
SOURCE: Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Posted on Apr 07, 2008
  • 927 Answers
SOURCE: loud humming noise when you power on the toshiba
Good Day,
It sounds like you have Color Wheel That Going bad To verify disconnect cable Color Wheel ***'y. NO noise= bad part.
Good Luck, Big Irish.
Posted on Nov 23, 2009
TV turns on then cutts off
that buzzing is the high end power trying to turn the lamp on.... the electrical current and shock is what turn your lamp on your tv which is what the buzzing is dont worry thats normal...however your solution is buy a new lamp for your tv but make sure its the right serial number for lamp u cant just buy any lamp. best place to buy one ebay.... as in the lamp still trying to light up its only because the electrical current going into the lamp and then cutting off causing the red light on your tv....so other words all it is is the lamp... CAUTION!!!! those lamps get up to 400 degrees unplug tv to ensure no electrical current.... hope i helped.... JACOB WINKLER
Jul 16, 2012 | Toshiba 46HM95 46" HDTV
THE TV IS MAKING NOISE AROUND THE LAMP OF MY TOSHIBA TV 46HM95 THE PROBLEM OCCURS UPON SWITCHING ON BOUGHT A NEW LAMP AND A NEW FUN STILL NO CHANGE AFTER INSTALLING.
U hearing alot of clickings,when the tv turn on?Yes,the board call the Ballast board is dead also.This Ballast board,job is to help, to ignite the projection lamp.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Oct 14, 2010 | Toshiba 46HM95 46" HDTV
Turn on TV hear a buzzing and then the TV cycles off and on again
Hi,If it seems you are experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.I found it with complete light engine assembly here: http://www.discount-merchant.com/TOSHIBA-2973026206-p/1160068.htm?Click=48173
Apr 16, 2010 | Toshiba 46HM95 46" HDTV
Toshiba model #46HM95 picture dims and brightens occasionally and just started to turn off by itself.
Replace the lamp first. If that does not fix it then you will have to send the light engine to Toshiba to be rebuilt. The ballast is bad but is not available any more.
Dec 02, 2009 | Toshiba 46HM95 46" HDTV
Loud humming noise when you power on the toshiba
Good Day,
Nov 22, 2009 | Toshiba 50HM66 52" Television
Toshiba 44NHM84 won't turn on
Usualy these problems are due to solder evaporating under the heat of the component.If you are a competent technician,by opening the tv set and by looking closely on the solder part of the board,
you should see a few that are not as shiny as the other, or look like a donut around the pin.these should be redone.those failiure are around the components that heat up:voltage reg,h-v reg and the
resistor around them.
good luck
Jan 28, 2009 | Toshiba 46HM95 46" HDTV
Humming noise in Toshiba television
my 46HM95 was humming also, I have the extended warranty and the company came out and diagnosed it as the light engine. the part was backordered and it was just fixed today, it was ordered back in February. Problem was solved.
Aug 12, 2008 | Toshiba 46HM95 46" HDTV
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Toshiba TV 46HM95
tv has a bad color wheel
Dec 28, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
