Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
My control lights flash 8 time on my jazzy pride
I re-install the battery's and the control light flash 8 times then it turns off. How do I fix it?
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 175 Answers
SOURCE: Go to turn the power on the controller of a Jazzy
Flashing lights indicates a fault. Here' the users manual which contains the fault codes for the flashing lights. Repost with more info re: the fault codes. Good Luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jazzy_1143_om.pdf
Also, make sure the charger is not plugged into the chair.
Posted on Jul 12, 2009
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Posted on May 18, 2010
Testimonial: "That was the problem, Thanks !!!"
My chair is blinking 4 times and I do not have a manual
If it is a Pride Jazzy or similar, the Diagnostic Flash Codes are in this PDF file.
PDF]INFINFB2048_Jazzy_Select_14_Troubleshooting ... - Pride Mobility www.pridemobility.com/download.php?f=troubleshooting/INFINFB2048_Jazzy...
  1. Cached
  2. Similar
basic troubleshooting instructions for the Jazzy Select 14/14XL power chairs. ... on my Jazzy Select 14/14XL seem to be "dead" (controller does not light up when .... What if the left red battery condition meter LED on the VR2 or VSI is flashing? chair is blinking 4 times Google Search
Nov 15, 2016 | Health & Beauty
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
What does it mean on 1122 jazzy when the two red lights blink
JAZZY 1122 - Pride Mobility Products
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1...
Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Jul 31, 2015 | Pride Mobility Jazzy 1122 Electric...
Lights on controller flashing
You can get the service manual from Pride's website. It will tell you what the flashes mean and how to fix it.
Apr 08, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Pride jazzy select turns on but when you try to move the battery light flashes 8 times then turns off.
Appear to be a problem with you control system. Check joystick module and power module connections. Look for frayed and damaged wiring.
Mar 24, 2013 | Pride Jazzy Select 6 Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Won't move lights are flashing on the controller batteries are fully charged any help
Doug I need to know how the lights are flashing ie 4 times pause 4 times pause etc or are all the lights flashing slowly or are the lights scrolling from left to right or right to left Thanks
Apr 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Problem with joystick on Jazzy 1103 ultra
Apr 01, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
66 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
