Question about Casio Watches
How do I change the battery on Casio 5015 watch?
4 Suggested Answers
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
mcdevito75
  • 1970 Answers
SOURCE: My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Posted on Jul 12, 2010
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Posted on Dec 30, 2010
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
How to replace battery in a Casio watch
You dont change the batteries on a Wave Ceptor. These watches have a battery cell that is charged by solar power. To learn more about your watch and download a manual, etc go to:
http://www.casio.com/support/
Best regards.
Aug 23, 2010 | Casio WVQ600DCA Wave Ceptor Watch
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
Hi I have got casio babyg 163 model.i believe it needs battery replacement but cant find the battery model any help plz
mcdevito75 here, Best Bet, look for a small watch repair shop in your area to cahnge the battery as any pressure on the display while changeing the battery on a Casio watch will break it.
Jul 03, 2010 | Casio BG163-4V Wrist Watch
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
SET AFTER BATTERY CHANGE
You need to follow the instruction manual after changing the battery.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Setting a Casio Wave Captor watch after battery change
If the watch is running try to sync the watch 1st, meaning set the minute and hour hands pointing to 12:00 o'clock. before you go to set the time.
May 22, 2009 | Casio WVQ600DCA Wave Ceptor Watch
Need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
May 14, 2009 | Casio Watches
I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
Watches Logo
158 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
