Question about Coffee Makers & Espresso Machines
How can i reset krups 7240 - Coffee Makers & Espresso Machines
5 Suggested Answers
SOURCE: krups xp 7240 cofee machine
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Posted on Apr 27, 2009
SOURCE: i need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Posted on May 14, 2009
  • 17 Answers
SOURCE: Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Posted on Aug 14, 2010
  • 1156 Answers
SOURCE: We require service/repair manuals for
unfortunately, the service manual for your Krups coffee machines :- XP 9000 XP 7240 XP7250 FNF 1 FNF unit is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Krups coffee machines :- XP 9000 XP 7240 XP7250 FNF 1 FNF via phone or e-mail and request for the service manual from them. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Good luck.
Posted on Jun 17, 2011
Error code 06 on Krups xpt 7240
Look for and remedy any internal leaks. If error 6 remains then expect to replace the distributor assembly.
Aug 20, 2014 | Krups XP Coffee Makers & Espresso Machines
Krups XP 7220 makes coffee but will not Eject the pellet of used coffee grounds. It makes a loud bang. Have discontinued use promptly. Any suggestions on dismantling, from above or below? Thanks in...
There is an arm that drops back into place just before the plunger drops to pack the grounds. After the espresso is pulled the plunger comes back up and the arm moves forward and swipes the pellet into the pellet container. My thought is that the arm has come out of sync or become disconnected. The sound you are hearing could be the mechanism trying to push the arm forward but snapping off.
As for disassembling, there are directions dismantling the unit on other posts here (for 7240 or 7230), but the one thing that wasn't so clear to me is that the front facade isn't secured with any screws, but rather hooks that are part of the molded construction of the facing. Once you pull up on the facade about a half an inch, it should pop off. You can see some of the six hooks in the pic below.palibaacsi.jpg
May 10, 2011 | Krups XP7230 Compact Super Automatic...
Hello.place for information for KRUPS XP 7240 -ERROR CODE 5
http://www.getvn.com/333/link/Krups+Xp+7240+Service+Manual.html
Nov 10, 2010 | Heating & Cooling
Hi, I just got the Krups XP2010 Espresso Machine & Coffee Maker, but it didn't come with the manual. How could I possibly get it? Hope you can help me get...
This was very difficult to locate, but I found it just for you! :) Please rate my answer 4 thumbs up on the site here, it is very important to me. I would be forever grateful. Here is the manual for you, please give it a few minutes to load it's a somewhat large file. If you need it emailed to you please respond back to this post and I will email it over. Here is the manual (you will need adobe reader to view it, but you probably already have that installed):
http://www.krupsusa.com/NR/rdonlyres/B454517D-7214-428F-BE57-932CFACB3E97/7240/XP2010.pdf
Oct 12, 2010 | Krups XP2010 Espresso Machine & Coffee...
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Krups xp 7240 cofee machine says error code 06
- plug it back in
Good luck
Nov 01, 2008 | Krups Small Appliances Espresso Machine
Krups 7240 ground coffee not ejected
The best thing you can do is find the receipt and exercise the guarantee. The problem you have is not a simple fix.
Mar 21, 2017 | Krups Small Appliances Espresso Machine
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
