Question about Sony Playstation 3 (PS3) Console
No picture I have recently obtain a PS3. I went through the initail set up. When I inserted a game a screen came up saying I needed to update to 1.9 b/c the system was on 1.5. So I did, then when the game began loading the screen is black and I hear a ding. It is now doing this everytime a game is loaded. I can still reach the start up screen fine. It is just when a game is inserted and begins to load that the screen goes black. I have all standard equipment. I have set the settings to standard tv. Does anyone know what is going on.
  • 709 Answers
You need to try to Update your PS3 from a memory card. Follow the directions on www.playstation.com to download the update using your regular PC and copy the update to a Memory card that has at least 120Mb of free space.
Go to www.playstation.com. Click on "Playstation 3", then click on "Playstation Network". Click on "System Update". Scroll to the bottom of that screen. Click on the next to last bullet called "Update using a PC" Follow the directions in detail.
Posted on Nov 10, 2007
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Midnight club la wont work on ps3 after i did a game update of it
Is there a yellow light on front instead of green? Is the disc scratched?
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
I just recently bought a PS3, the 80gb model and i've been playing Infamous for the past week and have gotten pretty far in the game. today, i switch on the system to play it and all of a sudden a red...
Its a problem from the system. Try re-updating the console... to the latest firmware... then try playing the game. If that does not work... call in the PSN
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 nothing appears on my television!!!
ok, put your ps3 in standby mode(solid red light) then hold the power button. Just keep holding it until the picture shows up, asking you if you want to set in to optimal video settings, in which you say yes. if it turns of before saying this, try again and again. if after a few tries it doesn't work, check the cables in the back of the system and tv to make sure they're plugged in fully. then check to make sure your tv is on the right video setting (video 1, 2, 3, digital output, etc.)
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
Error loading "mirror's edge" on ps3
What firmware are you running?
What happened the VERY first time you inserted the game?
Did it require an update?
May 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Msg4 just won't start
the game is supposed to download it self to the ps3. but if it refuses to download u may need to do a system update.
Jan 25, 2009 | Konami Metal Gear Solid 4: Guns of the...
My 60 GB PS3 wont run PS2 games
Actually only 60GB PS3s supports PS2 games. But It requires particular firmware. In first instance try updating your system, then dissable the disc autoload function, insert PS2 game, and look at the game section if your soft will recognise it. If yes just try to play
Good luck
Aug 07, 2008 | Sony Playstation 3 (PS3) Console
Pes2008
That's the best way to do over your PC to your USB. Create a folder on the storage media in which to save the update data.
Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  • Download the update data and save it in the UPDATE folder created in step 1. Select here to start the download.
Notice
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data.
  • File name: Save as file name “PS3UPDAT.PUP”.
    Update procedure
Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select (Settings) > (System Update), and then press the button
The folder name must be in all uppercase letters.
    Update procedure
Notices
  2. From the home menu, select (Settings) > (System Update), and then press the button.
  3. Select [Update via Storage Media], and then press the button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to (Settings) > (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
You can delete the update data from the storage media or USB device after the update has been successfully completed.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
102 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
