Question about Pride Health & Beauty
Pride celebrity 2000 will not go - Pride Health & Beauty
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: pride celebrity deluxe comfortcoach 1v problem-
Usually when a scooter dies, there is an event that preceded the dead state that caused the fault. What were you doing before it went dead?
The biggest culprit for scooters and power chairs is moisture. With a scooter, there are two components most susceptible. One is located inside the top of the tiller and it is an electonics board about 6"x4" in size. If you had the scooter out in the rain without protection over the tiller, water can encroach into this area and short the board. Or, a coke or coffee spill can short it. There's a fuse on the board and if it is blown, then likely the board is shot as the fuse merely keeps the tiller from going into a total meltdown in the event of a short. Boards run about $25.00 to $45.00 to replace. Inspect it and look for any signs of overheating or corrosive buil-up and see if the fuse has blown.
The second component is located under the shroud beneath the seat. It is a small metal box which is the power control module and it controls all of the operations of the scooter. It has several wires going into and coming out of it (on-board chargers for some scooters will only have one wire going in and one coming out, sometimes two). These boxes are water resistant, but are susceptible to damage if the scooter has been run through a puddle and a lot of water has splashed up onto it. These are several hundred dollars to replace, but first check all of the fuses coming off the batteries that will lead from the battery to this control box and insure that it isn't a blown fuse. These fuses generally don't blow unless the scooter was operated beyond its capabilities, like driving it in sand, mud or other unstable terrain that puts an enormous strain on the motor and pulling a lot of juice from the batteries. Finally, check all of the connections that clip together. Don't rely on a visual inspection, take them apart, and reconnect them all to insure a good, tight fit.
Hope this helps.
Posted on Aug 28, 2009
gewiz
  • 1263 Answers
SOURCE: Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Posted on Oct 12, 2009
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
  • 692 Answers
SOURCE: Lost key to Pride Celebrity
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
Posted on May 05, 2011
What size batteries go into a celebrity x mobility scooter with four wheels
Pride Celebrity SC400 SC4001 Battery Replacement Kit
There is technical support offered at the Pride Go Go website. The site above simply offers a replacement. Further specifications may be obtained from them or a manual.
Pride Mobility CELEBRITY Owner Manual
Aug 12, 2017 | Health & Beauty
What do pride celebrity x sport error codes mean
Download the otherwise fairly useless Pride owner's manual, the beeper codes are listed there.
Jun 12, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
May 05, 2011 | Pride Mobility Products Pride Mobility...
2000 pride celebrity sc440. has had pc board replaced 2 times. intermitten times it just dies. i clean all connections, and then it works for a while. it just died again. i found a broken resister,...
Hi donmorrill
Dosen't sound like the board at all. Sounds like you have a connection problem front to rear harness. I have worked on many celebrity 2000's and have found a bad connection with symtoms like yours. In the rear you will find where all the connections are plugged in. Check each one for continuity. Clean all connections, also make sure the little metal connectors are intact in the anderson connectors. But you do have a harness problem.
Good Luck
mimobility wizard_s.gif Wiz
May 02, 2011 | Pride Celebrity X 4-Wheel Electric Scooter...
Turn key on pride celebrity scooter. everything looks normal-all lights on does not run. i am a mobility tech
As a mobility tech you can log onto the Pride Service website and access the technical troubleshooting guides. There is a good one for the Celebrity X . If your company has a dealer account with Pride you can go on-line and request a log-in for tech/dealer access for illustrated parts breakdowns,parts ordering, service manuals and trouble-shooting guides etc. It may take 24 hours for the log-in approval but if you call in the AM they may be able to expedite your request. iPride and Pride service are very effective in providing all the information you will need. Hope this helps.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
May 25, 2010 | Pride Mobility Products Celebrity XL
Pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Problems with Pride Celebrity X 4-Wheel Electric ScooterFree tech support for Pride Celebrity X 4-Wheel Electric Scooter and help with Pride ... the scooter suddenly stops. it is an intermittent problem....
Jun 20, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Health & Beauty Logo
27 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
