I have BOSCH WFH 2460. Is there a program that can clean the inside of the circle rubber only with water?
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
Bosh wasmachine doesn't was clothes
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
Mar 23, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
My bosch wfd 2460 won't spin and drain
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Nov 16, 2009 | Washing Machines
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch 2460 won't spin
only brushes in motor ,he taking the mikey motor only 236.00 from bosch
Jun 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfr2460 part number question
Try repairclinic.com  We were able to find parts for our Bosch WFK2401 washing machine and our Asko dishwasher...they list the part descriptions and show pictures.  It might take a few minutes to sift thru the things but i bet you can find your part.  FYI, shipping has been great...just a day or two to arrive after ordering.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
