Question about Moen DN0708CH Iso Pivoting Toilet Tissue Paper Holder - Chrome
How do I remove moen toilet paper holder - Moen DN0708CH Iso Pivoting Toilet Tissue Paper Holder - Chrome
5 Suggested Answers
agent91
  • 2100 Answers
SOURCE: HOw do I remove the moen toilet paper holder from
Without looking it up, I can figure it has a tiny screw on the flange bottom, and when it is loosened, it will come off, then the holder, keeper, is screwed to the wall. If it is not held on by a little screw, setscrew, then try turning the whole thing off, it might be threaded. Hope this helps.
Posted on Jun 12, 2010
aviral_srms
  • 1216 Answers
SOURCE: My Moen Monticello Toilet Paper
  • 1 Remove toilet paper from the toilet paper holder.
  • 2 Examine the toilet paper holder to locate the screws that hold the toilet paper holder to the mounting brackets located behind the faceplate. Use a screwdriver to remove the screws. If you cannot find screws, the toilet paper holder may slide onto the mounting brackets. Gently pull up on the faceplate to slide the toilet paper holder off the mounting brackets.
  • 3 Unscrew the screws holding the mounting brackets to the wall with an appropriate screwdriver. If the holes are stripped, or the screw turns but will not back out, use your fingers to gently pull the screw out while turning to reduce damage to the drywall or enlarging the holes.
  • 4 Tap the hollow wall anchors into the holes with a hammer until the drywall anchors are flush with the drywall.
  • 5 Place the mounting brackets on top of the hollow wall anchors and insert the screws that came with the hollow wall anchors through the toilet paper holder mounting brackets and into the hollow wall anchors. Tighten the screws with a screwdriver.
  • 6 Place the toilet paper holder faceplate on the mounting brackets and insert screws to secure the toilet paper holder to the mounting brackets or slide the faceplate onto the mounting bracket, depending on the type of toilet paper holder installed.
  • 7 Place toilet paper back in toilet paper holder.
  • Posted on Oct 10, 2010
    • 82 Answers
    SOURCE: Where can I purchase Moen Monticello Satine
    you should be able to purchase these all online at moen.com good luck
    Posted on Dec 17, 2010
    • 1739 Answers
    SOURCE: I installed a Moen Sage toilet paper holder. The
    It is likely that the the mounting post on the wall has pulled loose.
    You will need to remove the paper holder and inspect themounting posts; loosen the set screws in the base of the posts to do this.
    Try tightening the screws holding the mounting posts to the wall. If the screws are unable to hold tight you will need to replace the wall anchors if they have been used.
    Remove the mounting posts and the wall anchors and replace with new wall anchor, preferably a toggle anchor designed for sheetrock if possible.
    With the wall anchors in place attach the mounting posts and install the paper holder; tightening the set screws in at the base of the posts.
    Installation instructions for your product can be found here:
    http://www.moen.ca/shared/pdf/yb2208sp.pdf
    Posted on Dec 22, 2010
    Moen dn8408ch fell off the wall post. How do I reattach?
    There should be a set screw on the bottom. Position the holder on the mounting plate and re tighten screw. It takes a pretty small flat head screwdriver. Here is the pdf format manual for this holder.
    http://www.moen.com/shared/pdf/dn8408sp.pdf
    May 15, 2011 | Moen DN8408CH Preston Toilet Paper Holder,...
    How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
    The technical specifications and installation instruction for your product are available here.
    At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
    You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
    Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
    I installed a Moen Sage toilet paper holder. The right cover that attaches to the wall hardware via a small screw is loose and no amount of tightening corrects the problem. What am I doing wrong?
    Oct 18, 2010 | Moen Home
    HOw do I remove the moen toilet paper holder from the wall
    Jun 11, 2010 | Moen DN0708CH Iso Pivoting Toilet Tissue...
    How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
    there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
    Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
    Moen DN0708CH Iso Pivoting Toilet Tissue Paper Holder - Chrome Logo
    88 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
