Question about Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
Stihl 012 av - Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw
  • Stihl Master
  • 1,807 Answers
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
What years was stihl chainsaw model # 012 AV manufactured?
i am not 100% sure but is around mid 70's
Aug 07, 2012 | Stihl Garden
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Need a bar and chain for slihl 012 av rollomatic
Right column, about 2" down "Bar Selector", just fill in the blanks.
http://www.baileysonline.com/
Only you can determine your level of expertise and how much danger of kickback you are comfortable with. Stihl brand bars and chain are only available through a local Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 26, 2010 | Garden
The starter rope doesnt pull, and when the saw is
sounds abit like it ,but remove the spark plug and you should be able to rock the flywheel back and forth. sounds a bit like no oil in the gas or at least insuficient oil and may have grabbed, (i assume you have the chain and bar off the powerhead,if not then remove them ,and then try ) it could also be the centrifgal clutch jammed up.
Dec 29, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Stihl Chainsaw Throttle Trigger 012 O12 Chain Saw Logo
82 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
