Home | Kyocera | KM-1505 Grayscale Copier | "C6000"
Kyocera KM-1505 Grayscale Copier
Problem for Kyocera KM-1505 Grayscale Copier
"C6000"
By marasini377 on Jun 23, 2009
Dear sir i am Barun from Nepal i have a proble wit km 1635 copiers .
i don't know that problem may be be smaller or grate, my copiers' display seems "C6000" then nothing to display . copier dosen't work after seems.What is this Problem? I know like that problem manaintance by code but Idon't know about code, please
I hope that u will send me about this code pleze . waighting ur mail.
Yours
BARUN
Solution #1
posted on Jul 06, 2009
Not Rated)
copiergeek
Rank: Guru
Rating: 94%, 28 votes
Hi Barun,
if you punch the following codes into your keypad it may fix or at least give us a good indication about what is happening to your copier.
1087 1087
you should see 000 on screen
punch 163 on your keypad and when it stop flashing turn off the copier.
when you turn it back on the copier should work, if not then you will have to get the fuser replaced.
Was this helpful?
Yes
No
Solution #2
posted on Jun 27, 2009
Not Rated)
FixinFax
Rank: Guru  Office Equipment  Expert
Rating: 85%, 512 votes
You have a bad FUSER assembly.
Was this helpful?
Yes
No
Popular Solutions for Kyocera KM-1505 Grayscale
Questions and Unsolved Problems for Kyocera KM-1505 Grayscale
Do you recommend Kyocera KM-1505 Grayscale Copier?
Answer
Answer
it shows me de code a 400 what does it means how can i solve it
Answer
when am try to get phoyocopy from KM 1500 kyocera machine its showing in display meter as an J 111
Answer
I am getting standby-downloadin error on ir-2016 can some one solve my problem
Answer
When I switch dispaly shutdown standby then shutdown frequently
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera KM-1505 Grayscale...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
