Question about Intertherm Heating & Cooling
How do i clean coils inside intertherm unit - Intertherm Heating & Cooling
    Sergeant:
    Champion:
  • 234 Answers
Do you mean the inside coil? If so the plenum on the furnace will need to be opened and sprayed with a coil cleaner, preferably one that foams. If you have pets you might need to take the cover on the end of the coil off and take a vacuum cleaner or shop vac and clean the hairs off the coil. You don't need to rinse as it will clean its self when running.
Posted on Nov 26, 2014
2 Suggested Answers
keith91gmc
  • 52 Answers
SOURCE: TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Posted on Aug 24, 2009
Best way to clean indoor airconditioning coils
Open up unit locate evap.coil with small brush clean coil then use evap.coil cleaner its self rinsing but if you can wash with hose without getting water inside home do so.
Apr 02, 2013 | Intertherm P3RA-048K Air Conditioner
My intertherm ac unit is freezing up outside ,why? are there any recalls on these units
Few things cause this. Poor or no airflow inside the furnace, dirty filters, poor filter placement that will cause your indoor cooling coil to plug with dirt, or low freon pressure.
Jul 26, 2011 | Intertherm P3RA-048K Air Conditioner
Hi. I have an Intertherm air handler and central air unit in my mobile home - Model # (E2EB-012HB) air handler, and a (03QA- 036U- B) A Coil.Simply put, When the cooling unit it running, it cools very...
The A coil (Evaporator) is dirty and needs cleaned by a professional. Dirt has clogged the fins in the coil and is blocking most of the airflow through the coil so the air has to go around the coil picking up the water as it does and sending it everywhere.
Has a service tech remove and clean your coil and reinstall it and your problem will be solved.
Jun 20, 2011 | Intertherm Heating & Cooling
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Water leaking onto floor
at night disconnect power use flash light and mirror check to see if coil is stopped up if unit is up flow coil fan heat kit make sure there is a trap in the drain line or unit will pull air into system most likley cause is dirty coil hope this helps unit could also have dirty fan blades low air flow or starting to freeze the coil due to low freeon charge if down flow supply duct under unit ths is not good due to heat kit on bottom of unit can get wet! hope this helps with your problem
Jul 04, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
How to clean?
Go to a ac supply house and tell them you need a good coil cleanner at about $10:00 a gallon.
Aug 10, 2008 | Intertherm P3RA-048K Air Conditioner
Self contained intertherm ac unit
make sure the unit is level or even off a little to the drain side. I have seen this cause this problem several times.
Aug 07, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
