Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Not cooling, compressor cycling, checked start up relays
Have gladiator garage freezer/refrigerator older model, 7+yrs, not cooling, thought it was start up relays, changed out and still not working, compressor cycles and drawing about 12amps during it short cycle (about 10 sec). compressor come hot but inlet and outlet are same temp. I tested to see if there was a open circuit on compressor, it tested good and its not shorted to case as well. could it be working and the cooling or closed circuit have a blockage somewhere blocking the compressed gas from entering the evaporator coils?
  • 1 more comment
  • ahmooksang Jun 23, 2009
    to be low on freon, would that mean that it had leaked out?
    so to repair, i need to first find leak, then recharge system, then hope nothing else is wrong. might be time to throw in the towel
    yeah their clean.
  • 351 Answers
Very possible or it is low on freon maybe
Posted on Jun 23, 2009
  • Mark Nichols Jun 23, 2009
    yes
    Yes that is correct, if everything seems to be working and you are not cooling either you are blocked, or you have no freon... the evaporator coils are clean right?
My Dad has whirpool Gladiator it only cools to 50 deg in the freezer . We unpluged it and let it set over night to see if it was a defrost problem.Compressor cycles and then shuts down @ 50 deg Still will...
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it.
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Whirlpool Gladiator Refrigerator
Hello-- My Avanti refrigerator is not cool enough (it only goes down to 45 degrees). It's about 6- 7 yrs. old. Any thoughts on why that would be? Thank you.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | Avanti Refrigerators
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our gladiator bottom freezer/refrigerator stopped working while we were on vacation last week. The motor still runs, but the air blowing out is not cold. We cleaned it out, unplugged it and plugged it in...
It is possible that your compressor has redduced in pumping or the gas pressure has redduced, ;leakage of gas. Sicne you had put off the fridge for sometime and tried again without any result, I think the compressor needs a good check. Since the fridge has to cool definately when the motor runs we must start from here . I hope you check this out or maybe get help to confirm definetely with an estimate. Good day.
Aug 02, 2010 | Gladiator GAFZ21XXMK Bottom Freezer...
The refrigerator compartment not cooling, freezer is ok so far
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
469d
Jun 03, 2010 | Gladiator 19 cu. ft. Chillerator Garage...
The freezer is frosting up on my Whirlpool Gladiator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | Whirlpool Gladiator Refrigerator
Power on but not cooling
mostly either compressor or relay is bad. replace relay and see if it works, since that is cheaper part..
Jan 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
295 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
