Question about Palm TX Handheld
Com1 port not available on new PC
Got a new PC yesterday and am trying to get my Palm to sync - get above error message
  • 473 Answers
SOURCE: Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Posted on Sep 11, 2005
cropp
  • 377 Answers
SOURCE: Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Posted on Mar 26, 2008
SOURCE: selected com port not available
we are having the same problem hotsyncing treo 755p with vista home premium for months. No help from Palm or Sprint. Have uninstalled and reinstalled desktop Access 6.2.2 repeatedly without success. Handheld will still hotsync with older XP computer. Hellllp
Posted on Aug 05, 2008
Just_Bobz
  • 448 Answers
SOURCE: Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Posted on Jan 01, 2009
  • 62 Answers
SOURCE: Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Posted on Mar 23, 2009
How do I open COM1 in Windows 7 Pro?
Com1 is the Communication Port. A serial Port located on the computer and usually 9 pins.
Feb 18, 2014 | Computers & Internet
Palm set to COM1 not serial connection-won't sync
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Normal 0
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Nov 10, 2009 | Palm Z22 Handheld
I have a Dell Inspiron 530 using Vista Home Premium and have just tried to reintroduce a Palm M130 which I used on my last computer with Windows XP. It worked ok then. Now I cannot find the COM1 port. In...
is the printer connected to the pc or have u ever tried installing the printer on the pc as by default the printer is kept on com1 port
just check & let me know if the issue is resolved.
Apr 17, 2009 | Compaq Evo D310v PC Desktop
Com 1 port
Yes. com1 Should be labled Serial Port on the PC.
Feb 09, 2009 | E-Machines etower 500is PC Desktop
Syncing to a Treo and COM1
Uninstall activesync, reinstall and setup new connection.
Oct 14, 2008 | Dell Dimension 2400 PC Desktop
Selected com port not available
Please un-install and re-install the software,, that should fix the problem,
Jun 09, 2008 | Palm Treo 755p Smartphone
Hot sync
Try reseting the palm.
Jan 02, 2008 | Palm Treo 680 Smartphone
Ibm workpad sync & port issues help!
You have your Hotsync software set to use a com port instead of USB. Right Click on the Hotsync icon on the lower right part of your PC desktop and change it to USB and you should be good to go. The IBM Workpad is just like a Palm. I have the Workpad C500 which is actually a Palm M500. If you have a Workpad C505 it is a Palm M505. Anything you can buy for a Palm M500 will work with a C500 and anything you get for a M505 will work with a C505. If you do NOT have a USB Sync cable for your Workpad I suggest you do what I did... Just get a combination Sync and charge USB cable at Staples or Best Buy for your M500 or M505 and use it. It was about 20 but you can get them cheaper on the Net. I hope this helps you!
Sep 14, 2005 | IBM WorkPad z50
Sep 11, 2005 | Palm Tungsten T3 Handheld
When I try to do an IR sync to outlook Iget error message " error accessing the IR port see //helpnotes//IR_readme.txt
On you PC disable the "Image Transfer” functionality on the “Wireless Link” Control Panel.
Sep 07, 2005 | Palm IIIx Handheld
Palm TX Handheld Logo
29 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
