Question about Aqua Vac Tiger Shark
Aquavac starts for about 3 seconds and then just sits there
Why does the low voltage breaker kick off every time in turn the vacuum on?
Check to see if the ENTIRE suction system is free of debris. Empty your vacuum bag. Ensure that the brushes/wheels are moving and not jammed. Check for proper voltage to the system. If all of these items are ok, then it needs to be serviced.
May 16, 2014 | AquaVac Tigershark Plus Robotic Automatic...
Briggs & Stratton Quantum 120000 Lawn Mower; After sitting all winter with an empty fuel tank the mower after priming will start easy for 3 seconds and quit and repeating the process quits after 3...
This sounds like restricted fuel flow. Items suspect are pick up screen (in the tank), filter, hoses, and the carb itself.
You have to open it up to find out where the issue is.
Mar 20, 2011 | Garden
Turns on but does not move.
Thank you for posting your question here on Fixya.com.
Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. While your cleaner was made by Aquavac (Hayward) they work very much the same way.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 09, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Aquavac 42 tankless water heater: we cannot find a source for parts in US. Please help
Hello aknapton:
I just removed a working aquavac 42 from our home and upgraded. You can have the whole unit if you would pay for shipping.
It worked when we removed it. It was fussy about the standing pilot and had to clean the thimble jet a lot (dirty propane) but it did work. let me know. norm@finetuningauto.com
Jun 03, 2010 | Water Heaters
Loud instant 2-3 second rattle around the under
Check all braces under your car. Not just visually, put hands on each and every brace. Sounds like one might be loose or broken. Hope it's as easy a fix as mine was.
May 03, 2017 | 2004 Ford F150
I have a 1996 izuzu rodeo, when i let the car sit over night i go to turn the car on and i get no 3 second prime out of the fuel pump, if i throw a spray of eather in her, it will start right up, and will...
Try and turn the ignition over ,and over,then stop,then try and start it,if it starts,then the fuel pump is loosing it`s prime,check the fuel pressure regulator.
Jan 26, 2010 | 1996 Isuzu Rodeo
Aqua Vac Tiger Shark Logo
154 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
