Question about LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
FW LaCie Porsche ext. HD 250 GB. Light on case blinks and drive makes a clicking noise. Of course it won't mount on my iMac. Had the drive for quite a few years with no problems. Tried an alternative power cord - no help.
    Sergeant:
  • 173 Answers
Conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Posted on Jun 23, 2009
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
Strange noises, disk won't fully spin or start up...
Your AC adapter is "dying", and must be replaced.
Is it still under "warranty", i.e., you contact LaCie,
get an RMA (Return Materials Authorization) number,
they ship you a new adapter. If you ship them the old adapter,
within a week, they will _not_ charge your credit-card the $30.
Sep 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie 250Gb drive does not power up
It's the power supply connection in the HD case has failed. Try the HD in another case (if you have one handy) to check whether this is the problem. If so, find a replacement case.
Apr 30, 2008 | LaCie (300728U) 250 GB Hard Drive
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 HD Quadra 250gb
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Hope this helps.
Dec 01, 2007 | LaCie (300770) 250 GB Hard Drive
Lacie lost evrything and is now clicking
Not without a clean sterile environment. Exposing the drive to room temperture and environment can damage the internal platters. i am willing to bet it the drive as well, but the clicking sounds like a bad drive arm, and continual attempts to use it may make the drive arm tear into the platters.
www.drivesaver.com
Oct 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Power light blinking orange/yellow. does not mount or recognise
IN SPANISH...USE TRADUCTOR OR TRANSLATE.... TRATA DE USAR UN SOFTWARE LLAMADO PARTITION MAGIC DESDE LA SE?AL C: O SEA BAJO DOS.... PERO ANTES CONTESTAME TU BOOT O SOFTWARE DE INICIO RECONOCE EL DISCO DURO?... SI NO LO HACE O ES UNA DA?O LOGICO O SEA DE LA TARJETA DEL DISCO DURO, O FISICO, DEL DISCO EN SI, LO CUAL EXPLICARIA EL RUIDO.... HAY EN INTERNET SOFTWARE FREE.... PARA DIAGNOSTICO Y HASTA REPARACION... UNO DE LOS MEJORES SE LLAMA HIREN´S BOOT CD Y SE BAJA COMO UN ISO Y LUEGO LO GRABAS EN UN CD LUEGO HACES BOOT CON EL Y CORRES EL SOFTWARE QUE QUIERAS, INCLUYENDO EL PARTITION MAGIC, ESPERO QUE TENGAS SUERTE. SI PUEDO SERTE DE MAS AYUDA TENDRIAS QUE SER UN POCO MAS ESPECIFICO. HAY OTRO SOFTWARE BAJO LINUX LLAMADO KANOPPIX Y EL EN OCASIONES RECONOCE LO QUE OTROS SISTEMAS OPERATIVOS NO HACEN.... ASI POR LO MENOS RECUPERARIAS TU INFORMACION Y SI ESTAS DE BUENAS LO FORMATEAS DE NUEVO Y RECUPERAS TU DISCO. ESTE TAMBIEN LO CONSIGUES EN INTERNET Y ES FREE.
Jan 14, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive Logo
546 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
