Question about Craftsman Garden
Model 917.288520 lawn tractor
Where do i connect the clutch cable to activate the blades I checked the diagram but does not show where it connects to . Can you help
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
Replaced battery and will not make a sound
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MOWER BLADE DOES NOT DISINGAGE
You need to replace the blade clutch cable that runs between the blade engagement lever just to the right of the steering wheel and the the spring to the idler/clutch wheel on the top of the mower deck. Over time the cable binds in the sleeve/cable jacket preventing the blade from disengaging
Aug 18, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Light switch wiring
Yes.
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
http://waterheatertimer.org/images/GE-15312-single-a-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/OWB1.html
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Jan 22, 2012 | Cars & Trucks
On John Deere lawn tractor when we pull the yellow button up to engage the blades to start spinning, they dont move.
If you have an electric pto switch, the switch, connecting wire from the switch to the pto clutch, or the clutch itself could be defective. You can check the switch and wire with an ohm meter. You can also check for proper voltage at the pto clutch plug.
Sep 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dead battery
The blade clutch is electric. A bad battery might be interfering with the clutches engagement. You should make sure you have good contacts on the battery at both ends. Replace any battery cables that are excessively corroded. If the battery had removeable caps for filling you might want to check the electrolyte levels and top them off with some distilled water. You can also jump start your mower and check the voltage while running with the blade off. If you dont see voltage going up while the engine is running you probably have battery and charging system issues. The battery should have at least 12 volts with the mower off and 13-15 volts with the engine on.
A bad charging system would require repairs on the motor and should be handled by a local repair shop. At least you can rule out the diy stuff first though right?
Good luck and be caeful. Wear eye protection whenever working around batteries with jumper cables. Weak batteries give off explosive gases. Always connect the cables to the bad battery first and then the good battery to avoid sparking near the bad battery.
Jul 25, 2010 | Husqvarna 54'' Package Deal Zero Turn...
The mower deck clutch cable broke so blades will not engage and lever is loose on my Sears Craftsman 42-inch lawn tractor (917-271-742). I fished out the top piece of the cable, about 12 inches down to a...
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Jun 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
There seems to be a problem with the cable to the attachment clutch lever. there is no tension on it when I engage. blades wont go (may mow tiny bit). Is this someyhing I can fix. Manual does not have a...
check for a spring on your tensioner pulley there should be some holes on it for a spring to connect too and back onto the frame these sometimes come off and dont keep the belt tight maybe diagram will show this tensioner
Apr 25, 2010 | Garden
Garden Logo
70 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
