Question about Kenmore Washing Machines
Elite HE3 will not drain and pump makes grinding noise. Wet vacced all water out and opened pump clean-out and cleaned it. Stuck finger in pump impeller and it turned okay. Ran diagnostics and got same result: pump makes grinding noise. Do I need to remove pump and take it apart? Thanks.
  • 351 Answers
You really cant take them apart, you will have to purchase a new one and they run about 120$ or so call www.whirlpoolpartssurplus with model number
Posted on Jun 23, 2009
Washer stoped flashing code f21
you have something stuck in the pump or a bad pump,remove the bottom cover,look at the pump and you'll see that the center has a grove in it so you can grab it and turn it counterclockwise to remove it but first with a shop vac vac out all the water in the tub then set up the vac down near the pump,turn the center of the pump until water start to leak out,vac it up until it's drained and then remove the center piece,clean it out,also stick your finger into the pump and feelaround to make sure nothing is in there or in the impellar,check the rubber boot of the hose,you can stick the vac in there to see if anything gets vacced out,put the piece back in tightly,add some water,put it on drain,if it drains you're done,if it doesn't check the pump again,if it's clear you need a new pump,those pumps are hard to kill so most likely your gonna find some lovely stuff in there,also the water stinks from the detergent so get ready for the stink,it's always like that.hope this helps,if your washer doesn't have the pump that the center part can be removed just pull off the hoses and clean out the pump and check the hoses for any junk cought up in there.good luck with your washer
Oct 19, 2011 | Kenmore Elite 45986 Front Load Washer
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
How to fix fh error on a kenmore elite he3
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
Keep getting f21 error message and washer dosn't drain
take off the bottom panel,you'll see the pump and in the middle of the pump there's a catch cup,uncrew the center of the pump and your gonna find all kinds of good stuff.if you have a shop vac for water your gonna need it,turn the center piece slowly until water starts to trickle out and use the shop vac to clean out the water or you'll have a mess,put down a couple of bath towels too to catch the water,after you cleaned out the water remove the middle part all together and stick your finger inside and feel around the impeller to make sure nothing is stuck on it,also check the rubber drain hose on the other end of the pump,stuff can get stuck in there too.put it back together,if it still doesn't drain change out the pump.also check the drain line for kinks in it.i see this all the time,there's usually a couple of dollars worth of change in there and other good stuff,let me know how you make out
May 31, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite oasis gas dryer
Apr 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Clean drain screen on HE3 washer? I would like to clean the drain screen, but wanted to know how complicated it is getting to it and ease of cleaning it and replacing it. Thanks
if you talking about the drain trap, its very easy to clean. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Nov 25, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
How do you get to the drain filter on a kenmore elite he3 washer to clean it?
The following link explains how to access the drain pump on a Kenmore Elite HE3 front loader to clean the drain pump:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
123 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
