How can I diagnose the power supply unit in this set? I suspect it is the cause of my problem. Error code 23, screen shrank in and out a couple times and turned off a couple times, now wont come back on. clicks on and turns off after 3 secs. Green and blue guns glow orange at bottom. Red gun arcs in the tube and glows inconsistantly red... Would this likely be the PSU or maybe the flyback? Thanks!
The problem is the arcing red tube, it can be replaced or rejuvenated by qualified TV technician. The arcing is the result of a spark gap being formed in the picture tube resulting in a short between the HV anode of the tube and ground. Replacement of the tube is preferred, but the tube can be rejuvenated using a CRT rejuvenator.
i have an older projection tv and the red yellow and blue dots are showing through.projection dots i...
(More)
i have an older projection tv and the red yellow and blue dots are showing through.projection dots i believe also believe i''m missing a filter screen on front over picture does this cut those dots out? if so where can i find this or something that will work.asked around found nothing.
the TV will not turn on and the green light just blinks. The directions say to push the reset button...
(More)
the TV will not turn on and the green light just blinks. The directions say to push the reset button and wait a few minutes. We have done that and it still continues to blink. We have unplugged the TV over night and when we plug it back in it still blinks and we still can not turn on the tv. Any thoughts? Thanks
Mitsubishi W555809 TV won't start. Had a play station 2 hooked up for a couple of weeks and once...
(More)
Mitsubishi W555809 TV won't start. Had a play station 2 hooked up for a couple of weeks and once disconnected the TV won't go on. Won't go on if I reconnect it either. Thanks.
My dad's tv has sound but no picture mitsubishi television (model wd52528). BUT he messed with the...
(More)
My dad's tv has sound but no picture mitsubishi television (model wd52528). BUT he messed with the direct tv remote right beofre this occured. Problem with the settings or the tv?
