Question about Isomac Millenium Espresso Machine
Group head will not come off - Isomac Millenium Espresso Machine
La Cimbali junior group head leak after restore
Group head leaks can be caused by group gasket, portafilter basket (cup), valve, pipe fittings. Call back your service tech.
* Check group gasket and position of portafiler handle when pulling shot. The handle needs to point directly at you (your chest) if it points to your left shoulder or pops off the group then the gasket is worn, not correct size, missing spacer.
* If the handle points to the right shoulder then the gasket is, too thick, too many spacers, or it was installed without removing the old coffee (crud) from the group head and is stuck under the gasket. Remove and check group gasket and spacers.
* If the handle points directly at you but portafilter still leaks then check the basket (cup) insert. Many Barista's smash the portafilter on a bumper. If the bumper is worn and the metal bar is exposed then the basket insert will have a flat or dented lip. Check all your inserts for damage and replace worn bumper (a piece of water hose cut to size works)
* Still leaking? Remove cup tray above group and check group head for leaks around the pipes and fittings. Note: water discharge from bottom of group valve is normal DURING the pulling of a shot. It should not continue to drip water after pulling the shot.
* Still leaking? The group head needs to be checked.
* Pump, water lines, Water by-pass, Economiser, Hot water wand, and all the water fittings.
Aloha, ukeboy57 (youtube)
Feb 18, 2013 | Espresso RMI La Cimbali Espresso Machine
Direction replacing goup solenoid
As you have put it water flows from boiler to group head so the arrow on the solenoid should be this direction.
Aug 15, 2012 | Pasquini Livia 90 Espresso Machine
How do i use cleaning powder
Hi Dont use the cleaning powder yet. Remove the group head shower and clean it with steel wool, then clean the group head where the shower sits with sfeel wool. Remove the filter fron the group handle and clean the under side. Also clean the group handle before you put the filter back in. You shouldn't use powder in these machines, but if you do, you need to put a blind filter (filter with no holes in it)in the group handle. If you dont have a blind filter, you can use foil to cover your filter. When you have done that, you need to add a 1/4 teaspoon of powder into the foil covered basket and lock the handle in the group head. Switch the coffee button on for a few seconds then off again.Domt take handle out yet. Repeat this on/off proceedure 5 or 6 times. Now remove the handle and flush out any powder that is left. Leaving the foil in place, lock the handle back into the group head and repeat the above proceedure. This fushes out any powder residue. Make a coffee and discard. Now your machine has bee back flushed. Again, i do not recomend using powder in these machines. The poder can back flow into the boiler. Just make sure you give it a good flush. If you clean your group head and shower weekly, you'll never need to use powder. Dazza COFFEE MACHINE TECHNICIAN
Sep 26, 2011 | Rancilio Silvia Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
La Marzocco GB 5, 2 group head boiler not starting. It says coffee boiler 1 30.8 C. Please help
New machine? check the thermal reset on top of the left group head. Press the red button and see what happens.....
Aug 17, 2010 | La Marzocco Linea Series Group 3 Espresso...
Hi, no water through e61 group head ?
Check the metering jets and filter on the top of the group heads.
Jul 15, 2010 | Coffee Makers & Espresso Machines
My machine has worked beautifully for several years, but suddenly, I have issues with the group head. When trying to pull my espresso, I get leakage around the rim of the group head. Sometimes coffee...
I have had the same issue, this is just the group head gasket that needs to be replaced. I got all the parts and I am going to try and replace it myself
Jun 09, 2010 | Pasquini Livia 90 Espresso Machine
My e61 group head on my Diadema UNICO Splendor exhaust port probs
There might be one of 2 things going on,
1- the exhaust tube is blocked.
2- one of the three gaskets in the group is on backwards.
Jul 24, 2009 | Coffee Makers & Espresso Machines
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Isomac Millenium Espresso Machine Logo
13 people viewed this question
Top Isomac Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Isomac Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
