Question about Kirby Vacuums
Kirby is smoking?
Hi, Ive just been delivered a Kirby G, purchased online, and upon giving it quick test run (20 seconds) smoke started pouring out of the top. The manual was not included, so I have no idea what is wrong, how to go about fixing it etc. All help appreciated. Thanks!
Send it back
It smokes & has no manual
You don't want either situation
It is defective,obviously
Posted on May 12, 2014
  • Tahli Swain
    Tahli Swain May 12, 2014
    So I googled possible problems and it said the belt at the front would be the cause. I checked it, all was connected properly.. so I (possibly stupidly) turned it back and the motor caught on fire. Clearly been sold a defective machine. Sigh
  • 120 Answers
SOURCE: KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Posted on Sep 26, 2008
  • 69 Answers
SOURCE: Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Posted on Jan 28, 2009
SOURCE: kirby is smoking and breaking belts
First thing , make sure that the roller brush is turning freely.. should spin like a top.. free and easy, if not that is the problem
the bearing on the ends are seized up and it isnt turning and you belt is turning on the motor shaft, thus causing the smoke and burning
WPVAC
Posted on Feb 11, 2009
b0sslady2001
  • 357 Answers
SOURCE: kirby G6 vacuum smells ok smoke when vacuuming and
Try my troubleshooting guide...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps,
Marci
Posted on Jun 28, 2009
budgie140
  • 501 Answers
SOURCE: how to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Posted on Jul 01, 2010
Dyson won't go down, stay upright. As I forced it down and turned it on it started smoking. I unplugged and cleaned out by brush but it still won't go down and continues to smoke when turned on....
I'm sorry to hear you're having difficulties with your DC07. I'd advise against turning the cleaner on again, and encourage you to get in touch with us directly so we can help resolve this issue for you as quickly as possible.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 26, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
My Vacuumm kirby hertiage made a funny noise and started to smoke and doesn't work.
Remove the cover and change the belt it may have got a rock stuck in the beater bar(brush)
Sep 12, 2009 | Kirby Heritage II Vacuum
Where can i download a user manual for a Kirby G4? Thank you.
I haven't found one that is downloadable, however, you can obtain one by calling Kirby at 1-800-437-7170.
Jul 07, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby is smoking and breaking belts
WPVAC
Feb 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hi! I'm interested in purchasing a G3 model ; however , the seller says that the machine was working perfectly and then when switching power on a while later , the machine was " dead " . Other...
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums, I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Kirby Vacuums
KIRBY ISSUES! :(
Sep 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Kirby Ultimate G
Hi There, Could be a number of differant things really. Just check that the both the safety switches are being activated but other than that it will need to go to a repair center. Many Thanks Chris www.elidistribution.co.uk
Aug 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
70 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
