Question about KitchenAid Food Mixers
Kitchenaid mixer motor
Machine will not switch on i think the motor may have failed as i have power to the brushes
    Scholar:
  • KitchenAid Expert
  • 188 Answers
SOURCE: KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
Posted on Aug 19, 2007
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid stand mixer (kp2671xwh)
Hi Service Manuals are not given to customers. You can download parts manuals for your mixer which will assist you in disassembly and reassembly. Goto www.kitchenaid.com
Call Kitchenaid to order the parts. Be prepared to wait at least a month for parts to arrive.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 21, 2009
hslincoln
  • 235 Answers
SOURCE: k45ss kitchenaid stand mixer, i took out the brushes
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
Posted on Nov 03, 2009
  • 130 Answers
SOURCE: seating the brushes on the Kitchenaid ksm90 mixer
You don't need to seat the brushes. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Posted on Apr 21, 2010
My kitchenaid professional mixer will not run.
The Service Manual for your mixer can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Among the causes for the mixer not turning on are (in no particular order) --
The leaf-spring switch on the Control Plate is not making contact.
The Phase Board is defective.
Brushes need replacement.
Brush chamfered side not correctly oriented.
Bad armature or field coil.
Seized motor bearing.
Detached or broken Control Board spring.
Speed Control Link plastic end broken.
Jun 01, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Regreased kitchenaide mixer now won't turn on
Did you remove the carbon brushes. If so they go back in any of four ways. But only one way works correctly. If you did not remove the brushes then you need to set the speed timing on the speed control switch at the rear of the machine and you can find a YouTube video on this exact exercise on YouTube of course. You may have also reattached the wires to the speed control switch to the wrong connectors hence no work.
Sep 12, 2013 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid ksm no power
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer
3 the speed control switch inside the mixer
4 the carbon brushes inside the motor head of the mixer
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 25, 2013 | KitchenAid KSM150PS Artisan Series Stand...
My machine simply won't turn on .
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
Will not run
Will need to check if the motor is working the power to the switch and then to the motor.
Look for a reset switch on the underside which could have reset, this can happen if there is an overload on the mixer.
If the motor is not working check if the brushes are contacting, if not clean and set.
Oct 01, 2010 | KitchenAid K45SS Classic Stand Mixer
No power after replacing worm gear in Kitchenaid KSM90 Mixer
Remove the rear cap from the unit. Power comes in from the black wire with the white being common. Hold a voltmeter lead on the white and check for power on the black. Power goes across the bottom of the speed control unit via a buss bar. Check for power on the right side, I think it is a red wire (may be a white one). Power is taken into the motor via that wire, goes thru the windings and the brushes and then out the other brush wire and back to the board. Check for power on the return wire. If it is dead then either the windings in the motor are burned out or one of the brushes is dirty and needs to be cleaned and reseated prpperly [note there is one and only one way the brush goes in!!!! Install it incorrectly and the brush will not touch the commutator.
Try that and see if it runs after cleaning the brushes.
Mar 31, 2010 | KitchenAid Food Mixers
The capacitor on the speed switch is burning out.
I have found that the capacitor is no longer available, along with
any of the motor parts. Armature, brushes, motor end bearing, etc, are not available.
Dec 18, 2009 | KitchenAid K5AWH Stand Mixer
Kitchenaid ultrapower ksm90
Yes, First unplug the unit.On either sides of the mixer there are two black motor brush retainer screws. Carefully remove them paying attention to the motor brush keyed position.You will see that one side is keyed.Check to see if the brush is competely worn down,or possibly cracked ( replace ).Always reinstall brushes the same way they came out.This should solve the problem.
Nov 03, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
94 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
