Set the time on daffodil pedometer - Office Equipment & Supplies
How do I change the time
Change the time on your pedometer this weekend ...
blog.walkingspree.com > Walkingspree
To change the time on your Omron USB Pedometer press SET and hold it ... AM and PM displayed on your pedometer or it will reset at noon instead of midnight.
[PDF]PEDOMETER - LuckyVitamin
www.luckyvitamin.com/.../Sportline%20Qlip%20Any-Wear%20Pedome...
8. SETTING THE PEDOMETER FUNCTIONS. SETTING TIME. 9. SETTING USER DATA. 10. OPERATING THE PEDOMETER. VIEWING PEDOMETER DATA. 11.
How to Set Up Your Pedometer - YouTube
? 1:51
https://www.youtube.com/watch?v=2Zgh9uDeA4w
Jan 31, 2016 | Exercise & Fitness
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
Can't set time on 3D Sensor Multifunction Pedometer
This site has pedometer manual to down load. Go to thesource.ca where you can download the manual for free.
Apr 02, 2014 | NexxTech Exercise & Fitness
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
Jul 31, 2013 | Exercise & Fitness
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
I cannot get my pedometer to count steps. I was able to set up the pedometer, I can work the stopwatch, but cannot get it to start counting steps.
Oct 06, 2010 | VIA Balance 50003 Via Step Pedometer...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    How do you set the gaiam pedometer alarm?
    yes - after setting time for alarm, press mode and set to get alarm icon on screen
    Jun 04, 2009 | Gaiam Walking Fit Kit Pedometer...
    I am having problems with my Pedometer. What should I do?
    Review the following questions for common pedometer troubleshooting: a) Where are you wearing the pedometer? Make sure you are wearing your pedometer correctly by following these steps: * Clip your pedometer to your waistband or belt, directly above your knee. * Be sure your pedometer is perpendicular to the ground, not angled or dangling from your clothing. * Do not wear the pedometer on your shoe, sock, pocket or wrist. It will not provide an accurate reading. * Test the pedometer for accuracy by setting the step counter to zero and walking 50 steps. Check the display. If the reading is between 45-55, your step counter is functioning properly. If it reads more or less, reposition the counter on your waist and check again. * Your pedometer may give inaccurate results if you have had recent surgery or knee, leg, or foot problems. You may be favoring a leg or foot while walking. b)My pedometer has a clicking or loose part sound? Is it broken? No, a clicking or loose part sound is not an indicator of a broken pedometer. Every pedometer has an arm or pendulum inside of it. This is what counts the steps. The clicking noise that can be heard when the pedometer is shaken (or when you are walking) is the pendulum. c)The reset button will not work. The pendulum inside the pedometer is linked to the step counting device. The pendulum may become immobile from time to time, and this can prevent the reset button on the step counter from doing its job. If pressing the reset button a few times does not clear the display, here is what you can do to release the pendulum: * Give the pedometer a few gentle shakes while keeping the reset button held down. This un-sticks the pendulum. * Release the button. If the display has not cleared, press and release the button one more time. * If the display does not reset after trying this once or twice, call Customer Service.
    Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
    115 people viewed this question
    jasbo
    jasbo
