Question about Honeywell Programmable Thermostat Heater
Blinking symbol similar to an asterik with a circle around it on my non-programmable thermostat
  • 29 Answers
Cooling mode. supposed to resemble a snowflake
Posted on Jun 23, 2009
  • jjjarvan Jun 23, 2009
Air conditioning not working. Have White-Rodgers thermostat 1F79111, I think. Replaced batteries. Now have flashing signal like an asterisk. What does it mean?
Blinking snowflake means it's on time delay for cooling to come on (usually 5 minute time delay to prevent compressor short cycling). Solid snowflake means cooling is on
Aug 03, 2016 | White-Rodgers (Protech) White Rodgers...
Does this take a battery?
If you remove the thermostat from the wall and look at the rear, you probably will find a battery compartment with batteries in need of being replaced.
Dec 30, 2015 | Braeburn 1220NC 2 Heat/1 Cool...
What is snowflake symbol
shows that the setting [temperature] is set to come on when a temperature inside gets below 2 degrees or zero
Apr 10, 2015 | Lux PSD111 Digital Non-Programmable Single...
Installed an rth2510 and installed as labeled on old stat and sounds like my ac nut is buzzing outside, any thought?
question: do you have a multiple thermostat setup in 1 zone? If so check what settings are for your heat on each thermostat. Make sure that the heat is not set higher than the room's temperature.
check what settings are for your cooling on each thermostat. Make sure that the cooling is set accordingly.
if you have multiple thermostats setup in 1 zone. the thermostat with the lowest temperature will reign supreme. The heat setting on that thermostat will be what's causing the buzz on the heater.
optionally, hard reset your thermostat as a precaution. Here's how to do so: there are two types of thermostats i know of programmable and non-programmable.
disable auto & enable manual; however do NOT change settings or power-off t-stat. Remove battery and power down the thermostat until you see nothing on the thermostat monitor; power OFF the switch connected to your t-stat. Remove battery and reinsert inverted, if needed, press whatever button that your heart desires to make sure that nothing is absolutely drawing into that mode, button, etc; wait (5sec-1min); remove batters; wait 1min; then, reinsert batteries in its correct position; if you have a programmable thermostat; do the same with the hit 'reset filter' held down observe if the roomTemp reading has changed.
May I suggest to keep an extra thermometer around to determine if temperature reading accurately?
If reset requires a reprogramming to your t-stat, do whatever required to set your desired setting.
cheers, best of luck. i hope i've helped.
background, doing a hard reset in my opinion is similar to removing the battery from a PC motherboard.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
I have a hp laser printer p2035 & the top symbol is blinking what is it?
This symbol represents a paper jam. Try removing the paper tray and opening any doors available to find the paper in question.
Oct 16, 2012 | Office Equipment & Supplies
What does a symbol that has mph with a circle around it and a 1 in the top left corner mean?
It's a programmable speed warning. Your owner's manual will describe how to cancel, adjust, or reset it.
Oct 07, 2009 | 2002 Audi A4
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Blinking symbol
Look for a reset selection on the thermostat. The Filter warning is probably programmed to come up on 90 day intervals.
Oct 20, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
539 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
