Question about Zanussi ZWF1440 Front Load Washer
Zanussi Jetsystem 1400 washing machine leaks from below the drum when filling to start a "wash" or "Rinse" cycle and from a point invisible from the top of the machine (top cover removed). What is the most likely source?
3 Suggested Answers
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
Posted on May 19, 2009
  • 6277 Answers
SOURCE: my Zanussi Jetsystem 1600 washing machine would
Sorry, don't know your particular washer but try this and no promises!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
What does fault code e30 on a zanussi jetsystem 1400
Activated anti-flooding device. Try to find leaks in the bottom of washing machine.
Dado
Aug 08, 2014 | Zanussi Washing Machines
Washing machine error
HOLD START AND SKIP TOGETHER AND TELL ME WHAT IT SAYS. Also give model and serial number.
Apr 25, 2013 | Washing Machines
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 22, 2013 | Washing Machines
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
May 19, 2009 | Zanussi Washing Machines
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem 1200 wahser dryer problem
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Oct 07, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
48 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
