Diameter of jupiter
Need orbit time rotation time and the diameter of jupiter
3 Suggested Answers
SOURCE: Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
Posted on Aug 15, 2011
i355bonzo
  • 97 Answers
SOURCE: Jupiter's estimated diameter with a single digit and a power of 10 is
1 earth...approximately
Posted on Apr 03, 2015
What is orotation
"orotation" is rotation misspelled.
ro·ta·tion
r??t?SH(?)n/
noun
noun: rotation; plural noun: rotations
  1. the action of rotating around an axis or center."the moon moves in the same direction as the earth's rotation"
    synonyms: revolving, turning, spinning, gyration, circlingMore "the rotation of the wheels" turn, revolution, orbit, spin
    "a rotation of Jupiter"
    • the action or system of rotating crops.noun: crop rotation; plural noun: crop rotations
    • Forestrythe cycle of growth and felling or cutting of trees.
    • the passing of a privilege or responsibility from one member of a group to another in a regularly recurring succession."it has become common for senior academics to act as heads of department in rotation"
      synonyms: sequence, succession;More alternation, cycle
      "each member is chair for six months in rotation"
  2. USa tour of duty, especially by a medical practitioner in training.
    "she was completing a rotation in trauma surgery"
  3. Mathematicsthe conceptual operation of turning a system around an axis.
  4. Mathematicsanother term for curl (sense 2 of the noun).
Origin
mid 16th century: from Latin rotatio(n-), from the verb rotare (see rotate).
Apr 11, 2017 | Miscellaneous
How far is jupiter from the sun
483.8 million miles on average. (Jupiter like most planets has an elliptical as opposed to circular orbit.)
Feb 26, 2015 | Meade Jupiter 60AZ-MF Telescope with Bonus...
What are some characteristics about Uranus the planet?
Hope this helps!
Mass: 86,810,300,000,000,000 billion kg (14.536 x Earth)
Equatorial Diameter: 51,118 km
Polar Diameter: 49,946 km
Equatorial Circumference: 159,354 km
Known Moons: 27
Notable Moons: Oberon, Titania, Miranda, Ariel & Umbriel more info
Known Rings: 13
Orbit Distance: 2,870,658,186 km (19.22 AU)
Orbit Period: 30,687.15 Earth days (84.02 Earth years)
Surface Temperature: -197 °C
Discover Date: March 13th 1781 Online Virus Removal and PC Help Contest
Feb 18, 2015 | Cars & Trucks
The orbit arm won't rotate but the orbit does
Good Afternoon Jamie Talbert, thank you for your post!
I understand that your orbit arm will not rotate on your Frigidaire dishwasher. Typically, to rotate that orbit arm it is the water pressure coming into your machine. If you have cleaned all the internal parts you may want to review that the psi coming into your dishwasher is between 20-120 psi. Once you have checked the psi it could be an internal issue with the orbit arm. You may need to replace that component. I would suggest reaching out to the manufacturer for proper pricing and availability. -Matt
Nov 19, 2014 | Frigidaire Dishwashers
A definition explaining what a astrouids is
do you mean Asteroids ?
They are small rocky bodies orbiting the sun. Large numbers of these, ranging enormously in size, are found between the orbits of Mars and Jupiter, though some have more eccentric orbits.
May 19, 2014 | Video Game Consoles & Games
How big s Jupiter?
Its diameter is about 70 thousand kilometers and its mass is about 318 times that of the Earth. See http://en.wikipedia.org/wiki/Jupiter
Sep 02, 2013 | Cars & Trucks
Cant seem to get the saw to rotate have a 12 amp orbital saw zall
if by rotate you mean the orbital action, could be a couple problems. first there is a pin inside the gearcase that rides on an eccentric shaft that one or both could be worn not allowing this. Also the lever mechanism that turns for the orbital might not be rotating fully. I would suggest before attempting anything that you go to Milwaukeetools.com and under parts/service download the breakdown so that you can see what you are getting into. DO NOT remove the retaining ring that holds the orbit pocket assembly into the gearcase, it requires a special service fixture to reinstall and it is no fun. Let me know if you need more assistance and I will try and help. Thanks
Feb 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
