Question about Cameras
I have the Canon 650D and my access lamp is red and blinks at times. Usually when i take or view an image. I googled it and it told me to format the card. I did that and now my card is empty with no images, and it's still red. I also charged the battery and and took it out (both battery and card) and put it back in a few times. Also used a different card but had the same results. I've had my camera for at least a year and haven't used it as much. I just know that my access lamp should be green. Is it being red and usually blinking a problem?
  • Cameras Master
  • 4,420 Answers
Formatting the card (as it will say in the menu and on the on-screen instructions when you perform this action) deletes all the data currently resident on the card. You may be able to use data recovery software to retreive them.
Posted on May 05, 2017
cammykins
  • 149 Answers
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
  • 298 Answers
SOURCE: Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Posted on Mar 15, 2009
fillmore85
  • 62 Answers
SOURCE: I own a Samsung HL-R5067W 50
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Posted on Oct 20, 2009
  • 12 Answers
SOURCE: My battery light indicator is blinking red. Does
Think you have a faulty charger, my dog chewed mine, then it short circuited a few times till i found the damaged cable mine light went red to then i repaired the cable and its been fine if you cant see a brake buy a new one off ebay I managed to get one for £9 delivered its new just not an acer one minus the plug cable so if thats boke your looking at no more than £15. hope this helps ..Marc
Posted on Jan 24, 2010
tvtek
  • 1284 Answers
SOURCE: kdf-50a11e blink 3 time on red
Three flashes indicates either the lamp is not seated correctly or the lamp door is not on properly. I bet its the later of the 2 as THE most common issue is the lamp door has warped because of excess heat building up in the lamp cage. If this is the case follow the link I am providing as you are in luck as Sony is paying for those repairs. Please take a moment to rate my answer...Thanks
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF50WE655
Posted on May 19, 2010
Testimonial: "thanks for your help now i have another code erreur 2 blink on red can you telme about this ereur thx ery mutch"
Why is red light blinking
The red lamp you are referring to is called the Access Lamp. This lamp usually illuminates if the camera is reading or writing information to the memory card. If this is blinking erratically, this could indicate an issue with the memory card. It is recommended that you try using another memory card with the camera to isolate the issue
Jan 20, 2015 | Cameras
Sony kdsr60xbr1 standbuy blinks red 6 times. Pulled lamp out, it was broken. I heard lamp pop. Do I just need to replace lamp or is it something else as welll?
If your not sure, google name and make of tv and "red light blinks 6 times". That usually is a code for what is wrong.....My money is on the lamp....especially if it was working fine before. Hope that helps and gd luck to ya
Mar 13, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
I HAVE A PANISONIC HDTV1808I PROJECTION TV MODEL PT-51HX42F ITS A 2003 YEAR IT WAS WORKING THEN WENT TO TURN IT ON AND NOTHING ITS POWER RED LIGHT BLINKS 5 TIMES THEN PAUSES AND STARTS BLINKING THE SAME...
You need to replace the "Lamp" check Google Shopping for pricing. Enter your TV model # and add the word "Lamp" Make sure you get a Phillips or Panasonic lamp don't get a Chinese knockoff. They don't last!. Hopr this helps.
Jul 02, 2011 | Panasonic Televison & Video
In Focus LP 640 won't even turn on? Any help
There are several reasons this could happen, and can usually be identified by glancing at the Power LED. The following applies to this particular projector:
1) Blinking RED led- Lamp or fan failure. Usually this is a bulb issue and simply needs the lamp replaced and the lamp life hours reset. Below you will find an image from the owners manual that will allow you to translate the # of times the LED blinks into a problem/solutionrobertsager.png
2) Solid Red LED means unidentifiable error. You will need to contact customer support at that point to schedule service.
Mar 07, 2011 | InFocus LP640 Multimedia Projector
I just replaced the projection lamp and i cannot see an image. green power light goes on for a few seconds then goes back and clicks back to red
HOW MANY TIMES IS THE RED LED BLINKING? IF IT IS BLINKING 3 TIMES MAKE SURE THAT THE LAMP DOOR YOU TOOK OFF TO CHANGE THE LAMP IS INSTALLED BACK ONTO THE TV AND IS SECURE.
Dec 17, 2010 | Sony KDF-50E2000 50" HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Black view finder
try a new memory card,many have been destroyed by photo-lab processing machines!
also,sticks DO go bad!!
Dec 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Black image
OK,
Its problem of bad ccd imager in Canon A60 camera and this part need to be replaced to get correct live view to take snap.
Canon will repair this camera free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Nov 15, 2008 | Canon PowerShot A60 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
