Question about Kenmore Refrigerators
70104000 owners manual
Kenmore Refrigerator Coldspot Model 70104000 how big is it?
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
woodchuck789
  • 4070 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
SOURCE: cubic feet size of Kenmore refrigerator
Try this site: http://www.kouba-cavallo.com/refmods.htm
Posted on Nov 12, 2009
livewire874
  • 618 Answers
SOURCE: Need a manual for the
Try this site http://www.manualsonline.com
Posted on Dec 03, 2010
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
I would like to know how big my Kenmore Coldspot Refrigerator is? It is model 106.51554104, Type 25 SSA. Made in 2003
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Oct 13, 2010 | Microwave Ovens
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Refrigerators Logo
263 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
