Question about Miele H348 B2 Electric Double Oven
Miele double oven H348 B2 oven door cooling fan very noisy and on a long time
3 Suggested Answers
  • 1462 Answers
SOURCE: H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
Posted on May 18, 2007
jyackle5
  • 8197 Answers
SOURCE: I need to replace my
Try calling maly at (800) 999-1360 to get your part.
Posted on Nov 22, 2010
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Why is our double oven fan so noisy?
u may need to first check if the fan is not impeeded by debris and oil build up etc. or have a broken impeller
Apr 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Cooling fan is very noisy
It is probably a worn fan bearing, or loose or broken fan blade.
You could try spraying the bearings with WD40,
which may quiten it down, but normally the only solution is to replace the fan motor complete.
[Please rate my solution.
Thankyou.
Jan 30, 2010 | Zanussi ZDQ495 Electric Double Oven
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
H348 B2
May 17, 2007 | Miele H348 B2 Electric Double Oven
Miele H348 B2 Electric Double Oven Logo
51 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
