Question about Panasonic RX-D29 Radio/Cassette/CD Boombox
Why won't DAB re-scan?
Can't get DAB scan mode to come up on menu or after pressing tuner/ band button on Panasonic rf-d1; worked well until yesterday, moved to different room in house- any ideas?
  • 172 Answers
SOURCE: Panasonic TZ3 - buttons wont work
Cable connecting the back panel buttons to main board processor may be internittent. You can buy a service/repair manual from ebay that shows how to dis/assembly.
Barring this, let it drop about 4 inches to a hard service covered with two paper towels on its bottom. Doesn't have to land exactly flat. This is equivalent to giving it a rap with a semi-hard(wood/plastic) rod.
Also try pressing ******* shell around the buttons, not the button itself, while pressing button as normal.
I know this sounds a little hoakie, but this sort of treatment can cause a connection to make contact, or make a contact temporarily, indicating a connection problem of some sort.,
Posted on Apr 02, 2008
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
  • 125 Answers
SOURCE: using the different buttons
Hey there,
I have the answer to your prayers. I am ill familiar with that type of camera but guess what? I have the following site where you can download a (pdf) file which contains the manual for your camera. I mean how great is that? yeah well click on the link below, download and you are set to go. Let me know if you have any more questions regarding your camera alright. Cool
Posted on Oct 04, 2008
projdoc
  • 2237 Answers
SOURCE: I cannot access menu screen on Panasonic PT-LB51E
there may be an issue with the button panel board or an obstruction under the buttons. if all are well, ther is an issue with the main board.
Posted on Nov 10, 2009
SOURCE: We have a Panasonic DMR-EH50 DVD player/recorder.
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Apr 24, 2010
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Hoe to auto search without remote control aiwa color television at215
Depending on the model sequences can be slightly different, firstly you must be able to access the "Menu" button on the TV, as well as the arrow and "Enter" buttons. These buttons are typically located on the left side panel of the TV.and may be the buttons for Prog + or - or Volume up or down . Generally speaking the same sequence of buttons you press to scan for channels are identical to those you press when using a remote. Play around with combinations and see what they do but dont dont hit the enter button until your happy that you know what it is doing, write down the sequences and button combinations so yo remember them for next time. Step 1: Press the "Menu" button, press the "Up" and "Down" arrow buttons to highlight "TV" menu and press the "Menu" button again to enter the TV menu.
Step 2: Press the "Up" and "Down" arrow buttons to select "Tuner Mode" and press the "Left" and "Right" arrow buttons to select the frequency band depending whats connected to your TV. (digital box or aerial)
Step 4:Press the "Up" and "Down" arrow buttons to select "Auto Search" and press the "Menu" button to scan for all channels that are available in your area.
May 10, 2014 | Televison & Video
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
I have a eur7711150 remote for a panasonic radio that was my dads.. i cant figure out how to change channels on the radio.. hate to sound so stupid but there doesnt seem to be a tuner or a seek button
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
I hope this helps.
May 05, 2013 | Televison & Video
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
Initial setup - I have Dish, is this cable or antenna? I selected antenna & now all I can get is "scanning channels". Also, I can't get back to select cable. How can I start over as if I...
Hello Susan,
I'm very sorry, my internet disconnected in mid-chat. To get back to set-up and select cable, please do the following:
1. Turn the TV off
2. Turn the TV back on
3. Press the "menu" button on the remote
4. Use the Down arrow on the remote to highlight the "TV" option - the third option down.
5. Press the "OK" button on the remote
You will now see options for "Tuner Mode", "Channel Scan" and "Channel skip" Make sure the orange box is encircling the "Tuner Mode" option (if not use the up/down arrows to select it) and then press the right or left arrow until it says "Cable" on the right hand side.
6. Press the down arrow to highlight "Channel Scan"
7. Press "OK" on the remote to start the scan.
When the scan is complete, the TV should revert to watching mode, if not, press the "Menu" button on the remote to exit the menu.
Once again, I apologise for losing the chat session. I hope the instructions above solve your problem.
Please let me know what happens, by replying to this message and I will assist you further if necessary.
Regards,
BElectric
Nov 19, 2010 | Element Electronics Televison & Video
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
URC-50 Uninversal Remote won't control a Dish VIP 612 DVR. Both Companies say one is RF and the other IR so they can't "talk" to each other. How can a person "get around this" without buying another...
I don't know about the 612 but the 722 I have has green tabbed control for IR control of output 1 and by default of tuner 1 and controls the OTA tuner and will work with many IR remotes if set to address 1--they don't send the address. The blue tabbed one is for RF-controlled output 2 and tuner 2. Setting it to single (vs. dual) mode allows either remote to control tuner 1 and swap to tuner 2 and do PIP. Unfortunately the 612 does not have this mode.I haven't had a combo remote work well with tuner 1 even. It is much better to use the Dish remote for most of the work, well only volume and power on the TV. There are a lot of buttons most combo remotes will not have control of. Hey, I have 2 VIP722 and the TV remotes on the chair arm.Check with menu-menu to see which address code and control mode is set. But if manual allows and you can pull tab after opening battery slide and change switch beneath, you may be able to use as IR remote in preparation for your combo, just to be sure controls sent correctly. (Hold Sat button until all light, press address 1, press # to set remote [lights go out], then press record to set receiver while you watch menu-menu. less than 10 sec per step.)-Ken
Jul 15, 2009 | Kenwood RC-R0720 Remote Control
Panasonic DAB RF-D1 Radio..
The internal 5v battery is flat
Aug 31, 2008 | Audio Players & Recorders
Panasonic RX-D29 Radio/Cassette/CD Boombox Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
