Question about Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
Figure 9-15 Impeller configurations - Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
Avanti w797 does not drain. impeller keeps falling off.
Go to the following link:
http://www.avantiproducts.com/products/id/489
at the bottom of the page, click on the pdf "parts and accessories"
Nov 24, 2013 | Avanti W797 12 lbs Top Load Washer - White
How to replace bearings
Must disassemble the pump from the motor. The impeller has RH threads so hold motor armature (do not damage it) and turn impeller CCW to remove it from end of shaft. Hold armature in left hand and rotate impeller with right hand, turning hand on impeller back toward your body, or top of impeller toward you. Don't know how else to describe it. Once you have the impeller off everything should come apart pretty easily.
If impeller is really stuck, you will need to figure out how to hold it evenly all the way around without putting pressure on blades. Strap wrench, home made jig, something that can put more pressure on it than your hand.
You may want to remove the motor field so that you can grasp the armature while removing the impeller, do this by removing the long screws from the end of the motor.
Gently pry, tap, slide, however you can, get the bearings off the armature shaft without damaging any parts attached to it like fans, or starter centrifugal weights. Those things can be removed if needed.
Put new bearings on by sliding over shaft and seating in place by driving against the center race only. Do not drive bearing on by striking the outer race to move the inner race, this will damage the bearing.
Aug 14, 2012 | AO Smith SQ1152 Pool Pump Motor
I can't remove the impeller on a 4hp Speck pump...I've worked on several 3/4 to 3 hp pool pumps but this one is a first...also, how is the seal plate attached? maybe I'll figure that out if I'm able to...
If the shaft seal has been leaking for some time the stem on the impeller has likely spit due to corrosion on the motor shaft. This makes it near impossible to un screw the impeller. You can try and isolate the armature of the motor and use a channel lock on the impeller. The only other way to get it off is by breaking it. Use a flat head screwdriver and a hammer and break apart the area around the center of the impeller until you can pry off the everything but the stem. You'll have to remove the ceramic part of the seal and pick out as much of the stem as you can. Then you can get the wetend off the motor and remove the metal cup seal.
Oct 16, 2010 | Waterway Executive Spa Pump 4hp Impeller...
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
I need to replace the motor, but I can't figure out how to remove the blower fan.
This is usually a job for an appliance service company. However, the exhaust blower impeller is typically screwed on to the motor shaft. You will need to wear gloves and get a tight hand grip on the impeller, while using a wrench to unscrew the impeller at the motor. The impeller can be screwed on so tight at the manufacturer that, occassionally, it is necessary to chisel or break the impeller into pieces, and then replace it with a new one!
Feb 22, 2010 | Kenmore Dryers
IM TRYING TO FIGURE OUT HOW TO REMOVE IMPELLER TO REPLACE SEAL 2001YZ 125 LEAKS WATER
The impeller screws onto the impeller shaft. Go to the site below and you can see a parts diagram. You will select the brand, year, model, etc... It has the part numbers and prices.
http://www.babbittsonline.com/pages/parts/viewbybrand/1/Yamaha.aspx
There are actually two seals. Are you sure the leak is a bad seal and not the water pump gasket or a cracked/broken housing cover?
Please post a top rating for this solution. Thanks! :)
May 19, 2009 | 2004 Yamaha YZ 125
Removing water pump impeller
you might have to split the case to get to the back side of the impeller.
Mar 28, 2009 | 2004 Yamaha YZ 125
Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Feb 24, 2009 | Pool & Spa
Re & Re drain impeller
it may have been pressed on at the factory using a well-designed shop press. a gear puller may work along with a strong hair dryer to heat it up
May 28, 2007 | Maytag 24 in. MDB9150A Built-in Dishwasher
Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
24 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
