Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Where can I find a replacement water reservoir lid for my coffee maker?. The plastic peg that depresses the white button on the grinder lid broke off
I have searched all the replacement part sites and other than buying a used coffee maker to salvage this part I don't know what to do. I may have to jimmy-rig the broken one with super glue!
SOURCE: Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Posted on Jun 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Coffee maker brews too hot
The 1-4 setting makes the coffee extremely hot. If the 1-4 setting was not activated, make sure you are not using paper and permanent filters at the same time. If you are not using them at the same time, it is time to clean the coffee maker out with 2 cups vinegar and two cups water.
-Tha Mp3 doctor
Posted on Jan 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Posted on Feb 26, 2009
  • 4 Answers
SOURCE: coffee maker is leaking water
6300mobile restriction code send
Posted on Apr 13, 2010
  • 1739 Answers
SOURCE: this coffee maker (10 c maker with grinder) beeps
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Posted on Jan 30, 2011
Can I replace the grinder in my saeco odeo giro?
yes see the next steps. and fix it. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the HEATING ELEMENTS and the switch, thermostat, and timer .
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Oct 15, 2012 | Saeco Odeo Giro Automatic Espresso...
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I've triggered some alarm and I cant turn it off! I'm using a Cuisinart DGB 600 Coffeemaker, that is. I pressed "Program" thinking that was how to set the tine; held it down for a long time; and now it...
OK, here's the owner's manual for your coffee maker. I've got to run out for dinner, otherwise I'd give you the step-by-step, but the manual contains all the info you need to resolve this.
Also, it's nice to have a manual for any other issues you might come across, (programming auto brewing, cleaning, etc.)
Print and download a copy to save on your PC for future use and reference too.
http://www.cuisinart.com/share/pdf/manuals/dgb-600bc.pdf
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Cuisinart DGB-600 Coffee Maker
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cannot get "beeping" to stop
Try the following if you opened the cover and unit beeps. This will happen if you set up the coffee maker and then decide that you want to add more water and coffee before starting it:
You will notice that there is a small white (typically) button on the clear cover of the coffee grinder. When it is in place and the lid is closed, the button depresses a safety interlock inside a small plastic post to prevent the grinder from working without the clear cover on and the lid closed. Quite sensible from a safety perspective. Depress the white button to reset the switch or take a pen and carefully do the same. The beeping should stop.
Dec 17, 2008 | Cuisinart DGB-500 Coffee Maker
How do I properly clean the coffee maker and then get the light to go off?
  1. Allow the unit to cool completely and unplug it before cleaning. use a sponge dampened with soapy water to clean the outside of the coffeemaker, then dry carefully.
  2. Open the reservoir cover and the filter compartment. Remove the coffee grinder lid, the grinder, the filter basket, its cover and the support.
  3. Wash the pieces along with the measure, the carafe and its lid in warm, soapy water, rinse thoroghly and dry. Then replace them in the unit.
  4. All these pieces are also dishwasher safe.
  5. Never pour water inte the unit when the grinder is not in place.
  6. Wipe the part under the filter basket and the heater plate with a damp cloth.
  7. Do not wipe the inside of the reservoir as this may leave fabric or paper residue.
  8. Do not use abrasive sponges or cleaning agents as these could damage the finish.
  9. NEVER IMMERSE THE BASE OF THE UNIT IN WATER OR ANY OTHER LIQUID.
The reservoir cover may also be removed to facilitate cleaning.
Descaling.
Over time and through normal use, lime deposits will build up.
Scale can interfere with the fine mechanics and give the coffee a harsh, bitter taste. For reason, your coffeemaker should be descaled regularly to guarantee good coffee. The frequency of descaling depends on how hard the water is and how frequently you use the coffeemaker.
  • To descale, dilute 30cl white vinegar in 30cl water, pour the mixture into the reservoir and begin a brew cycle.
  • Then run two full cycles by filling the reservoir with water (but no coffee) to rinse the system.
Hope this will help you.
/Mirran
Aug 27, 2008 | Cuisinart Coffeemakers
What is the best method to clean the Cuisinart Grind and Brew coffee maker? And how often?
Get descaling solution at any drug store and follow the manual on the bottle. When you do this once a month that should keep your machine in top form
Aug 17, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
20 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
