Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Where is saniflo override switch - Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Saniflo not turning off after flushing
It could be a problem with the float switch that's bad, the micro switch may be stuck in the on position, or could be solids stuck at the float switch not allowing it to shut off. I suggest to open the unit and inspect the float switch.
Jan 07, 2013 | Saniflo & Saniplus& Macerator Pump
Saniflo motor running constantly
Depending on the model name, it might be a build up of waste at the bottom of the membrane or the membrane might be warped, if it is warped it will need to be replaced. Most Saniflo units have a pressure chamber and a membrane which activates the pump on and off, that could be the main reason why is not shutting off. Also you can refer to the installation manual or the schematic diagram. If you don have it you can download it from the Saniflo website at www.saniflo.com good luck with your unit.
Sep 02, 2012 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Top: Pump
indicates perhaps a faulty pressure switch. otherwise: this happens often in hard water areas due to build up of limescale. Use a descaling agent (acidic) to clean the saniflo - can be introduced via the toilet bowl.
Apr 02, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
My saniflo pump has stop working, what can be wrong
Have you got power to the pump? .. if it is on a fused spur, check that there is power (i.e. check the mains switch board)
Jan 17, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Hi there, we have a Saniflo system for a basement bathroom installed. The system stopped working so we checked the fuse box and it had tripped. We switched it back on and it worked fine for an hour. We had...
The saniflo system uses 2 stages stage one works sorta like a garbage disposal it breakes up waste, stage two is a high flo pump. one fo these has gone bad meaning the motor has burned up and shorted the sparking in the breaker pannel you refered to. As far as I know theese systems are self contained so you will have to have the unit repaced here is a link to the website so you can find a dealer or installer near you
http://www.saniflo.com/Default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Kitchen Appliances - Others
Describe your Saniflo &
your p-trap is dry . the guy who did it probably didn't vent it properly, and it's being syphined. call him back to fix it.
Sep 15, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
88 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
