Question about ASUS A53UXE1 156Inch Versatile Entertainment PC Notebook
How to replace space bar - ASUS A53UXE1 156Inch Versatile Entertainment PC Notebook
    Top Expert:
  • ASUS Master
  • 8,376 Answers
You will need to know what you are doing here.
most off them just clip off thats the easy bit,,if you watch how the old one comes off then you just put the new one on.
thay are held on with plastic clips and a long thin bar.
pluse some of them have little rubbers under them to make then come up when pressd down.
take care when doing this,good luck.
Posted on Apr 12, 2015
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
Space Bar Not Working
Have you gone into the device manager and trying to update the driver? If that's not it, try uninstalling it and shut down and restart the computer? It will reload your driver for you. That's all that I can think of.
Aug 06, 2017 | Computers & Internet
THE SPACE BAR ON MY LENOVA y530 CAME OFF- HOW DO i GET IT BACK ON?
You could try pressing the space bar key back into position since it has a small clip on the same part where the space bar key was held in position and incase if the key still pops off you would need to contact technical support to get the keyboard replaced.
Jun 01, 2010 | IBM Lenovo ThinkPad T61 Notebook
Space bar is not working, all other keys are working fine.
if the keyboard is too old and if you have used it a lot, then ou have to replace the keyboard. The space bar alone had gone.
Apr 03, 2010 | Logitech Wireless Access Duo Optical...
Space bar does not work
Hello, Thomas.
I'd suggest flipping your notebook on its side and then over, lift/pull the space bar slightly with a flat screwdriver or other thin, flat object. First shake, then spray compressed air in the area.
Hopefully, something is lodged (like a paper clip or other small object) and will be removed.
If not, the space bar cannot be replaced, unlike other keys. So, you would need to replace your keyboard.
Hope this helps.
Hope this helps.
Dec 22, 2009 | KDS Valiant 6480iPTD Notebook
Replacing the space bar
The bottons on the keyboard can be removed and replaced. I'm sure there are any number of parts available if you've some how lost your space bar entirely. Might be easier to just replace the keyboard though.
Aug 13, 2009 | Microsoft Wireless Desktop 3000 Keyboard
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Space bar does not work??
If the space bar won't go down there may be some debris under it,
DickyO
Dec 10, 2008 | Lexmark Wheelwriter 1000 Typewriter
ASUS A53UXE1 156Inch Versatile Entertainment PC Notebook Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
