Question about Lifespan Exercise & Fitness
Lifespan treadmill model turbo
Control panel lights up, but start, speed and incline buttons don't work all other buttons work, could somebody please tell me if they know what is cussing this problem
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
SOURCE: Hello - when I turn
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Posted on Sep 13, 2011
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
I have a Gold's Gym Trainer 480. model ggtl39608. Everything was working fine. Now the incline will not work & the control panel will not light up.
This problem needs more details to service....seem like you have multiple problems...better to call for service 877-805-1030
Jan 01, 2014 | Golds Gym Exercise & Fitness
I have got E06 error in Lifespan Treadmill.
I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.
Else
Call Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
Oct 01, 2012 | Lifespan Exercise & Fitness
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
I have a Nordictrack Solaris C2050 with the controls not always working. Sometimes the panel and contrals with perfect other times only a few buttons work, like the 7MPH, reduce speed. This problem is...
I have the same issue I don't think anybody (including the supposed "experts") really know what they are talking about. The buttons work until they don't and then a bunch of them all stop functioning at once. The advice I always get is "replace the console" which amounts to saying "I don't know what's wrong" If I had to guess I think a static discharge has damaged the contoller board which doesn't manifest itself until the machine (and hence the board) warms up. Anyhow I haven't found a real solution to this issue if anyone has any real knowledge please post your solution.
Apr 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Start and speed controls not working properly
do you have the magnet in place on the cut-off sensor? it sound like this is missing, as the treadmill will not turn the belt without it.
Apr 18, 2009 | Computers & Internet
Exercise & Fitness Logo
22 people viewed this question
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Mike
Mike
Electro Med Services...
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
