Which key is safe mode
Which key do I start tapping when I turn the computer on to get to safe mode
    Problem Solver:
  • 6 Answers
Once you turn the computer on and the BIOS screen goes away, you start tapping F8
Posted on May 12, 2014
4 Suggested Answers
computafixa
  • 317 Answers
SOURCE: start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Posted on Jan 09, 2008
siawolf
  • 749 Answers
SOURCE: Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Posted on Oct 08, 2008
SOURCE: keep getting black screen with error message no bootable device - insert boot disk and press any key ... computer will start in safe mode if i'm quick enough with the f1 key ... HELP
Hello good day, just remove your SATA cable from your hard disk if your using a SATA type HARD DISK, change with a new one, or try to pull it back and put it back tightly. It's just a loss contact situation.That's why you are receiving that message.
Posted on Mar 15, 2012
How do I turn safe mode on on a galaxy avant?
The information is here
Turn on and use safe mode Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily remove all apps that may be causing a conflict or software problem. To turn on safe mode and use it to fix app problems, follow these steps:
Turn on safe mode
  1. Turn the device off.
  2. Press and hold the Power key.
  3. When Samsung Galaxy Avant appears on the screen:
    1. Release the Power key.
    2. Immediately press and hold the Volume down key.
  4. Continue to hold the Volume down key until the device finishes restarting.
  5. Release the Volume down key when you see Safe Mode in the bottom left corner.
Uninstall third party applications
  1. Continue in Safe mode.
  2. From the home screen, tap Apps.
  3. Tap Settings.
  4. Scroll to 'APPLICATIONS,' then tap Application manager.
  5. If necessary, swipe right to the Downloaded screen.
  6. Tap the desired application.
  7. Tap Uninstall.
  8. Tap OK.
Turn off safe mode To turn off safe mode, follow these steps:
  1. Press and hold the Power key.
  2. Tap Restart.
  3. The device reboots in standard mode.
    Safe mode Samsung Galaxy Avant
Jan 16, 2016 | Samsung Galaxy Cell Phones
How do I start Lg-g3 T-Mobile in safe mode
Turn on safe mode
  1. Turn off your phone and reboot.
  2. When you see the LG logo, press and hold the Volume Down key until you see the home screen.
  3. Your home screen displays Safe mode in the lower left corner as shown.
Uninstall third party apps
  1. From any Home screen, tap Apps.
  2. Tap Settings.
  3. Scroll to 'APPLICATIONS,' then tap Application manager.
  4. If necessary, swipe right to the Downloaded screen.
  5. Tap the desired application.
  6. Tap Uninstall.
  7. Tap OK.
  2. Tap Power off and restart.
  3. The device restarts in standard mode.
May 14, 2015 | T-Mobile Cell Phones
How do I get out of safe mode on my dell vastro 2521?
Once you have solved the problem that sets it in "safe mode", you can reboot the computer into normal mode.
Look in the Control Panel.
Pick device manager and look for a yellow balloon, which will show why it is still in safe mode.
Mar 06, 2015 | Dell Inspiron Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Computer wont start
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
If same problem persist, boot from safe mode. Here's how;
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected, not Repair Your Computer
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If same problem persist, try reloading the Vista again.
Hope this works.
Mar 15, 2011 | Microsoft Windows Vista Home Premium...
My hp g6o stoped working right.How do I get to safe mode?
1. Reboot your computer
2. Press F8 constantly
3.Choose Safe mode
Thanks
DiegoTech
Nov 13, 2010 | Computers & Internet
How do I put my HP computer in safe mode.
Just after post(the computer boots up) and just before you see windows booting press F8, it will bring up a blck page with different selection options to boot your pc, use the arrow keys to go to the top of the page where it says safe mode and hit enter,, the computer should now boot to windows in save mode. hope this helps.
Sep 23, 2010 | Computers & Internet
Stars then says frequency out of range
start your computer in safe mode. Here's how to do it.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
once the computer is in safe mode, click on start > run and type desk.cpl. go to settings and then screen resolution. drag the slider to the left for the lowest setting. then press apply then ok. and restart your PC.
Nov 11, 2009 | Computers & Internet
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
