Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP AIO 6110 taking forever to print
My hp 6110 is taking soooo long to print a simple document. how do i fix it? I just reinstalled software anything else?
  • jessejmitche Jun 23, 2009
    thabnks but it did not work. I am usuing vista i think that might be it. i might just ditch this oner and buy a new onw.
I have vista too, but thats not the issue. You can fix this in two ways. The first is to push the button on the front of your printer that is under "Copy" and then "Quality" and change it from normal to fast. You want to do this before you send the print job to the printer. The second way is to open the printer file up (type the word "printer" in the search bar under "all programs" in the start menu), and then change the default printer setting quality to fast draft or draft. That should do it for you.
Posted on Jun 25, 2009
    Brigadier General:
  • 4,090 Answers
Cant speak for the model you have but generally withing control panel... printers there is a control screen for your printer under properties that shows what resolution of print is being used Fastprint... High qualit... and super print
If you can see this then reduce the resolution to quick print and see how it performs then.
Posted on Jun 23, 2009
Hi, my HP OfficeJet 6110 doesn't print when something is listed in the queque. It also takes forever to delete things in the line. I've also had issues where the cartridge has to be aligned, and every time...
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you're lucky, this might be all you have to do. Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer's software from the manufacturer and reinstall it.
Nov 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My 6110 hp officejet printer will not print. In the printer box the document has the word "error" next to it. How can I fix this? By the way it prints fine on my desktop just not on my laptop
I would reinstall the drivers for the printer on the laptop, making sure that:
1. if operating systems are different between the your PC and your laptop, you will need to download the appropriete software.
2.if using a USB cable, ensure the drivers are installed BEFORE you plug in the USB cable.
3. check the printers installed on the laptop, making sure that your officejet is the DEFAULT printer..
Please post here again with your findings
Regards.
Jul 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 printer takes a long time to print, like hours for 1 page
reinstall the printer driver software then restart the computer and printer. you can download the latest printer driver software from your printer manufacturer's web site.
Jun 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp all in one stopped scanning
if you have dial up your in for a long night,otherwise it should be fast.also make sure you look and install the scanner driver.good luck
Apr 14, 2009 | HP Photosmart C4280 Aio Printer
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
After clean reinstall of windows xp sp2, hp6110 software will not install properly
does the whole software program show up under:
my computer
programs?
Does an icon show up in the system tray?
Did you install IE7?
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Mac OS 10.5 Leopard
I was able to get my 6110 to scan by downloading HP_Installer_PSC7100_v9.7beta.dmg .  I saw this on XLR8YourMac for another HP multi-function and on a lark I decided to try it.  During the installer it won't detect the 6110, but you are able to "Skip" to the next step until it's installed.  Then, launch "HP All-in-One Device Chooser" and you will see the 6110 listed.  After I choose it there, I was able to use "HP Scan Pro" with the 6110.  I've not really tested the rest of the applications.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
