Question about Whirlpool Washing Machines
Can some one help me??? My washer won't agitate
Can some one help me??? My washer won't a gitate properly I don't know if a part is missing I don't see the cam & dogs that suppose to be there. Its a very old washer. Please I need help?????
  • jjguzman_can Jun 23, 2009
    model # is LA558OXMFO
    that is the model # maybe the washer is toooooo old???
  • 351 Answers
The model number would help me out in answering this question, feel free to call our free tech support and order parts from www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • Mark Nichols Jun 23, 2009
    im sorry im not bringing anything up with that number
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Remove agitator
Remove the cap and there should be a visible screw ,take that out and uou should be able to lift the gitator out
Sep 21, 2011 | GE WWSE5240G
WON'T AGITATE
Hello there and thank you for choosing fixya
If your Maytag top load washer is not agitating properly, you will need to check each one of the parts below until you find out which part you will need to replace to get your washer working properly again.
The free videos in these pages will show you how to do each one of the repairs the right way.
  1. How to check & replace belts
  2. How to check & replace spring & glides
  3. How to check & replace the transmission
Jun 29, 2011 | Maytag Legacy Series Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
The agitator isn't working at all
if this is the only problem solenoid on rocker arm there are 2 solenoids one for spin and one for gitator
Jun 12, 2011 | Washing Machines
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
