Question about Frigidaire Freezers
Why is my freezer compressor hot - Frigidaire Freezers
  • Frigidaire
    Frigidaire May 15, 2014
    Good Afternoon Friend, I understand that you are having trouble with the compressor being hot on your Frigidaire freezer. I will be more than happy to assist you. If I could please have your model number, so I am able to better assist you. You can find the model number located inside your freezer, on the right or left hand wall. Looking forward to hearing from you. WP
Why are the sides of my upright freezer hot and the compressor very hot
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
On a up right freezer the red light comes on and stays on and everytihng defrost what could be wrong
I want you to feel the top of the compressor to see if hot or too hot to keep your hand on the top. Click Here for a photo of the=> FFU2124D System Components item 30 is the 216649315_Relay-and-Overload-Kit item number 55 is the=> 5304464438 Run Capacitor
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
Nov 28, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
My compressor is really hot
If the compressor is almost too hot to touch, then you have a concern and need a repair technician. It is normal for the compressor to be a little warm, but not too much where you cannot keep your hand there.
Jul 20, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
My freezer is working fine, but my compressor is hot to the touch. Is the compressor too hot? I have converted my freezer to a kegerator with a temp. regulator. I do not want to burn my house down or...
the compressor will run hot,but you should be able to touch it without burning yourself.(when you compress a gas, heat is generated as it turns to liquid and when it expands back to a gas it absorbs heat,the principal of a fridge...)
Oct 23, 2010 | GE Freezers
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
Upright freezer hot to the touch on the sides.
inspect the unit for a fan near the compressor not to be alarmed some do not have a fan if so insure that it is running while the compressor is running also some defrost problems will cause this the unit runs for a long time heating the compressor and by way passing the heat along
Aug 13, 2009 | Freezers
Compressor getting hot
The compressor as well as the evaporator coils will get hot when the freezer is getting cold. Simple principle: Refrigerant gets cold and there must be an equal reaction, something getting hot. Just like the heat transfer in your car with the engine heating the radiator which dissapates the heat. hope this helps you, Rick
Apr 24, 2009 | GE Freezers
Freezers Logo
67 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
