Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Jumper setting under stand that no jumper setting required for SATA hard drive . now on my dvd which is still use IDE , set jumper as master , it reads alright as IDXE master and it show my SATA hard drive ...try to install OS on to it .... it gets to " computer is inspecting your system " .............and back to setup again and agian ..........please help
  • 1 more comment
  • vincent paya Jun 23, 2009
    i set my dvd on IDE as cable select ..........and new SATA no jumper .. still got the same problem can not load OS . I t came back and forth " sert up is inspectiung your computer hardware ......." please help
    so should I set dvd rom as slave .... and new hard drive as master ( no jumper setting required , isn't it but it has pin at the back of it , i guess just leave it alone )
  • vincent paya Jun 25, 2009
    this is the only HD on my system ....so I should set my dvd as cable select and HD leave it like that ? think I have done that . or the other way around .........................HD as cable select and dvd as slave . mobo is asus with only one IDE slot and floppy 4 SATA slots for HD .... it show both in bios but cannot boot.
    Sergeant:
  • 173 Answers
Ok
check your ide connectin that blue end of ide cable always at motherbord .also check that your ide cable is working properly.
Posted on Jun 23, 2009
  • Amit Jun 23, 2009
    ok
    set your sata master as your harddisk and dvd ide as slve.
    Sergeant:
  • 199 Answers
Set jumper to cable select or CS also you have to enable drive as active for it to boot to it. you can only have one active drive but up to 4 bootable particians.
  • chrisbock Jun 23, 2009
    do you have any other hard drives in your computer, and are you tryin to over write an existing OS.
  • chrisbock Jun 25, 2009
    ok on the ide cable you have 3 connectors one to thew mother board the next one closest to the mother board is the master slot the last one fartherest from the mother board is the secondary slot set the dvd rom as master and plug it in the master connector or cable select it doesent matter but plug it in first. plug the sata drive in both connectors. i prosume that your are trying to load vista. when you install a new sata drive and have never done it before you must load scsi drivers other wise you computer does not know what the drive is. it is just how it works then you should have no problem. if you could i would reccomend not installing Vista but it is up to you. Win 7 is comming out soon. it is really nice i have loaded the RC and it is great.
How do I set the jumpers to make it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 10, 2011 | Hitachi Computers & Internet
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
On bios the primary ide master is reading [pioneer dvd-rw instead of the hard drive
Have you got the DVD and Hard drive on the same IDE channel? You need to set the Hard drive to the IDE master channel (IDE 0) and the DVD to the Secondary master (IDE1) on the motherboard.
This way, if you need to ever re-install the OS you will not have any problems.
The only way , apart from a corrupted bios, that the DVD will read as master is if it is plugged into the IDE master socket.
I'm assuming you have the jumpers set to the master configiration on the DVD and the Hard drive? Schematic on the hard drive will show where it is and the DVD is set to master (looking at the back of it) when the jumper is on the rightmost set of pins.
If the above do not apply , or you have already sussed this, remove the bios battery for 2 minutes and press the power switch (computer unplugged of course) then replace. If this does not cure the problem, I'd download a bios update and flash the bios
Jan 10, 2011 | Sony VAIO VGC-RA840G PC Desktop
Need jumper settings for slave drive WD1600JS
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
2,432 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
