Question about GPS
Us state begining with I - GPS
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GPS Master
  • 102,366 Answers
Illinois, Indiana, Iowa. Take your choice.
Posted on May 26, 2014
How to get tdc
there are over 6 ways.
to attain TDC #1 firing,
on all engines, you never stated what engine is in your car.!
nor what state engine is in, nor how you lost it. (heads off?)
or?
on all V6 and V8, #1 is the most forward cylinder, look carefully see that? that is true on all cars.
then, if the engine is all buttoned up, (is it?) you cant watch the valve actions, making it impossible to see them.
so... i pretend that is your case, worst case.
there are 2 ways, in THIS case.
the blow test, or the compression test.
1: some put tissue paper in #1 spark hole
then rotate crank pulley by hand until it blows out. this is the compression strock , the begining then keep moving until the
crank pulley zero degree mark aligns with the pointer.
you are at TDC #1 firing now.
2: same deal but use a compression gauge.
when the gauge begins to rise. bingo, its on the beginning of the compression stroke, moving up. stop at zero.
done.
there are vastly more easy ways with valve #1 clover off.
Jul 13, 2014 | 1998 Chevrolet K1500
We have a new Frigidaire FASG7074NR2. It stopped at the beginning of the cycle and read door open. The door was not open. We tried opening and firmly closing the door and unplugging but it still reads door...
Good Morning Frances,
I understand that your new Frigidaire dryer, model# FASG7074NR2, stops at the beginning of the cycle and states that the door is open. I also see that opening the door firmly, closing the door firmly, and unplugging your appliance, the display still reads "Door Open", and will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine why it is stating "Door Open". I hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Fasg7074Lr 7.0 Cu Ft Gas Dryer
Nissan xterra comsume much gas
no stated amount, so cant begin to guess.
no engine stated.(size)
what prayTell is a Toyota, xterrra.???? and engine swap?
Problem with 1993 Toyota Previa Nissan xterra comsume much gas
Jan 04, 2014 | 1993 Toyota Previa
Memory card will not format
You need to put the micro card ( small ) in the adapter ( big ) if not it could be your camera
Dec 28, 2013 | Kodak PIXPRO AZ361 Bridge Digital Camera -...
OBII NOT READY SANTA FE
What state are you? can you go to the referee.? The monitor on a Hyundai dont set easy to begine with Give me your state
Feb 28, 2012 | 2001 Hyundai Santa Fe
When i try to enter a state ,I press ,say,f for Florida,I get Select State screen,and it is blank when i would expect to see States that begin with F for me to select from
NOT KNOWING WHAT MAKE , BUT CHECK THROUGH SETTING/PROFILE SCREEN FOR MAPS THEN A BOX SHOWING WHAT MAPS TO USE THAT SHOULD BE TICKED, IF NOT TICKED TICK THEM, COS IT SOUNDS LIKE YOUR UNIT HAS NO MAPS
Dec 18, 2009 | GPS
My 1993 buick lurches forward while at a complete stop or sometim
This is not a "how to" question but here's a reasonable answer: Your shop will generally charge an hourly rate to determine what the problem is. Generally the first hour is a given, and is not "pro-rated" or divided into parts of an hour. (twenty minutes therefore are billed as one hour) Then, depending upon what is found, the shop will give you a repair cost estimate ( IN MANY STATES, THIS ESTIMATE CANNOT BE EXCEDED BY MORE THAN 15% WITHOUT YOUR PERMISSION) Many shops will apply all or part of diagnostics charges towards repair charge. You must ask about this before any work begins. In many states, upon your request (ask before work begins), shops must return to you any parts which were replaced, and must guarantee their work for at least 60 days (this may vary from state to state). The cost of the entire repair will depend upon the shops posted labor rate and the time it takes to do repair, plus the cost of the parts replaced. Now you know the how and why of repair pricing!!! Good luck!!!
Feb 15, 2009 | 1993 Buick LeSabre
Setting the date
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Apr 28, 2007 | Timex 1440 Nylon watch
GPS Logo
26 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
