Question about Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater
Is there an alternative control panel I could use for a H259FDN?
My control panel will only control the "up" button but not the "down" so I am stuck with a high heat (I am turning off the gas to save a HUGE bill!). I will replace the control panel, however... I want to know if there is a different type of control panel that will fit with this make/model that has better controls? My old pool heater used to have an "off" button so if the temperature drops below the lowest setting of 65 degrees it doesn't start up unwantedly if the gas is left on accidentally. Thanks!
  • 790 Answers
Unless you have rigged your unit for remote control, this control panel is the only one listed.
You can check this link for contact information
http://www.hayward-pool.com/prd/In-Ground-Pool-Heaters-Universal-H-Series-Low-NOx_10201_10551_14002_-1_14003__I.htm
Posted on May 12, 2014
  • 139 Answers
SOURCE: I have a Hayward pool heater. It's about 5 years
would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Posted on Jun 20, 2009
  • 990 Answers
SOURCE: My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Posted on Apr 18, 2010
  • 4 Answers
SOURCE: electronic control won't allow me to bring the
Sounds like it could be the membrane on the front of the heater. Unfortunately with this type of heater you need to purchase the entire motherboard to get the membrane. Lots of other manufacturers sell the membrane separately but not Hayward.
Santa Clarita Pool Heater Repair
Posted on May 23, 2010
  • 990 Answers
SOURCE: buying a pool heater. Which brand best reliability
Both of those heaters are fine I prefer the Pentair for it's smaller footprint and ease of installation as you can turn it for access to plumbing. The Hayward is tougher to turn the exchanger on and you only have right or left as options for the plumbing to come out. Sta-Rite is still my favorite for installation being easy to plumb, wire and run gas to. It's very easy to change from natural to LP also.
Most heaters today are the same in reliablity and that is mostly up to you to keep the chemicals correct. Being in the business I always look to ease of install and access for repair.
Posted on Oct 17, 2010
Testimonial: "Thanks for info from an expert. Think I will get a pentair as they are sold in UT. Wholesaler doesn't even carry Hayward. So Techs aren't used to. "
john224
  • 1378 Answers
SOURCE: I have a hayward heatpro model hp2100. the heater
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
John
Posted on Feb 01, 2011
Display locked up on Coleman spa with bolboa instrument panel
Depending on which control system your Colman has:
Try these:
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position.
Hope that helps
Nov 03, 2012 | Pool & Spa
Cannot get temperature buttons on hot tub to change
Do the other buttons work? Is the control panel locked, some spas have a control panel lock to prevent kids from playing with the temperature. Are any of the buttons stuck in the de-pressed/down position? If neither the problem is likely in your topside control which means it will need to be replaced.
Sep 18, 2012 | Pool & Spa
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
Menu Scrolls Uncontrollably
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
I cant get the curser to work after turning off the acer joypad by mistake in control panel.Im on a laptop. and have windows vista
Press the Windows or Start button on your keyboard, and use TAB, or your down arrows to move to the Control Panel. Use Enter to make a choice, until you get to the cursor.
Jul 20, 2008 | Acer Computers & Internet
Canon ir 400s
Try cleaning the control panel and all the buttons/keys. If problem persists, try banging the keys individually. The control panel will not respond if any of the keys are stuck down.
Sep 15, 2007 | Toshiba e-Studio 205 Copier
Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Logo
70 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
