Question about Silverback X-Lite ATV Tire 30x10-14
Bearing replacement on silverback stride 30 mountain bike
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Buy a Harley Davidson bike, and donate that bike.
Posted on Dec 04, 2014
How to replace a bearing
contact your local bike shop for asistance
Aug 12, 2014 | Rocky Outdoor Gear Rocky Mountain Sherpa...
What is the replacement pedal bearing in a huffy mountain 24" bike?
at the Huffy quality level of pedals, you most likely won't be able to service the part, you can find a set of replacement pedals at your local bike shop starting at about $10 for the pair.
Apr 28, 2014 | Huffy Cycling
Need a bearing size or part number to replace a pedal bearing in a huffy stone mountain multi speed 26" bike
Pedal bearing or bottom bracket bearing? Your best bet would be to take it to a local Bike Shop and have them assess it.
Aug 04, 2010 | Huffy Cycling
Dyno mountain bike with a braking noise
If it is when you pedal, check the bottom bracket (where the cranks are attached) The bearings might need changing which would cause the noise.
Do the handlebars rock back and forward, if so, check and tightent the headset, check the bearings inside if they are dry or broken, replace and re-grease.
Jul 08, 2010 | Dyno Old School Gt Number Plate Old...
Bad crank bearings can move crank arms small amount.
That would depend on the style of bearings (loose ball or caged balls vs sealed bearings) and possible bottom bracket damage.
Either way, a Bike Shop mechanic would probably need to assess it for you. Special tools are usually involved.
http://parktool.com/repair/byregion.asp?catid=61
May 23, 2010 | Schwinn Mesa Gs Mountain Bike
Ball bearings fell out of handlebar connection on 3-speed bike.
Take it to a professional bike shop. They have the knowledge and tools to set it right.
Or take a look at this:
http://www.sheldonbrown.com/headsets.html
The headset nuts were not necessary to be moved for handlebar adjustment. Now the bearing load is too tight. Correct adjustment of the headset requires a delicate balance between tightness and freedom of movement. If your bike has/had the original bearings it's a safe bet they may be due for replacement anyway.
Apr 26, 2010 | Huffy Womens Mountain Bike - Passion...
The back wheel wobbles but its not buckled the rim moves
take it to a bike shop and have them replace the wheel bearings. i just had to have that done to mine
Dec 19, 2009 | Shimano Xtr Mountain Bike Dual Control...
I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Jul 08, 2009 | Mongoose MGX Maxim Dual Suspension...
How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Silverback X-Lite ATV Tire 30x10-14 Logo
Top Gorilla Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Gorilla Vehicle Part and Accessory Expert? Answer questions, earn points and help others
