Question about kawasaki Garden
Kawasaki lawn mower engine FH430V model
Engine starts ok but when cutting blade is engaged engine dies. Have replaced spark plugs, drained and replaced fuel and have serviced carburettor
4 Suggested Answers
  • 62 Answers
SOURCE: engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
Posted on Sep 19, 2009
  • 27 Answers
SOURCE: Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Posted on Jun 01, 2010
Testimonial: "Thanks, we will give it a try."
  • 27 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
23 hp Kawasaki FH680v engine losses power when engaging pto!
We had issues in the UK with issues like this, they would blacken and soot up the plugs and start to run on on cylinder, there was an internally vented carb rather than the externally vented carb to cure this.
Aug 10, 2012 | kawasaki Garden
I have a 21 HP Kawasaki on a 2007 Toro zero turn.Lately when I push the throttle forward the engine backfires and it will also backfire when I engage the blades it also backfires a lot louder when I shut...
the best thing to do is to clean or replace carb filter.. check spark plug for fouling clean or replace also if gas has been sitting in unit and stored outside I would drain gas because of water contamination..
May 26, 2012 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Engine starts but dies if you put a load on it such as putting it in gear or engaging the mower blade(its a rear engine rider) it did this 3 times, after the third time the spark plug wire started to smoke...
Carb needs cleaned as it can't handle the load of the engine and the deck at the same time. My guess about the spark plug melting is that the electronic ignition may have become hot while trying to start the mower causing the wire to melt.
Jun 23, 2009 | Garden
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalling Briggs & Stratton engine
carbeurator needs torn apart..cleaned and reset.
Sep 01, 2008 | Garden
Garden Logo
53 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Van Phelps
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
