Question about Maytag MGR5770 Gas Kitchen Range
Adjust oven door
MGR5770
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: maytag oven model mgr5770 oven hard to light and
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Posted on Aug 01, 2011
F3 error code
F3-Shorted or open oven temperature sensor. Here is the part to order.
Dec 08, 2012 | Maytag MGR5770 Gas Kitchen Range
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Takes foever to warm up. Oven Burner flame is
hey could you please go back and givce the chat session a good rating for me so i can continue to help others like yourself
l
Jan 03, 2010 | Maytag MGR5770 Gas Kitchen Range
Slow heating
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Maytag MGR5770 Gas Kitchen Range
What would cause incomplete combustion on burners and oven?
Look at oven burners while  they are lit. Is the flame coming from all of the holes. If not, see if the piolet or glow coil of ignitor is close enough to that side to make them light.Also make sure holes are not dirty (opened).The flame should be blue with just the tip red . If not adjust the air door to get more air and less gas. Their is also a gas ajustment on the oven gas valve on most. If the flame is jumping out of the hole,too much gas is coming through and you need to adjust the screw to get less gas flow. I hope I understood correctly and this is information that you need.
Dec 14, 2008 | Maytag MGR5770 Gas Kitchen Range
STOVE IS SHOWING F-3 AND OVEN WILL NOT GO ON.
most f-3 error codes are for the oven sensor. you sensor is probably bad and needs to be replaced. Joe
Dec 02, 2008 | Maytag MGR5770 Gas Kitchen Range
F9 code
F9 - Door latch supervisory (door latched) - Unlock door and check switches or clock assembly (also called the ERC)
Nov 21, 2008 | Maytag MGR5770 Gas Kitchen Range
Clock display/oven control panel
a few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Feb 25, 2008 | Maytag MGR5770 Gas Kitchen Range
Maytag MGR5770 Gas Kitchen Range Logo
20 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
