Question about Teac AG-D7900 Receiver
How to fix "PROTECT" warning? - Teac AG-D7900 Receiver
It stopped working now it is flashing the word protect what do you do
Unplug the speaker one at a time and see if the warning goes away. This protect warning you see usually indicates a shorted voice coil or speaker wiring.
Feb 23, 2017 | The Audio Players & Recorders
Protect problem
Cold solder joints can cause this problem
Jul 20, 2017 | Sony STR-DB780 Receiver
Warning light that looks like an engine
engine warning light . Comes on to tell you that the CPU has found some sensors that are failed . Check oil levels and coolant levels then run fault codes to find faulty sensors. Fix and do not ignore as it is there to protect the engine from failure.
Dec 05, 2013 | Oldsmobile Cutlass Supreme Cars & Trucks
Why Protect Sub Woofer warning and then power off by itself
Hello. My name is Dave. If the PROTECT lamp is on, you have a damaged amplifier, which will required a qualified audio tech.
Dave
Sep 30, 2012 | Audio Players & Recorders
How can i fix the EPC warning ligths on my 2005 audi a4 quattro 3.0
The throttle control can set a EPC condition this is where you get 50% power it is reduced the advantage is to protect the catalytic convertor. You will have 2 setting one in the engine compartment and one on the driver floorbardcansmo_55.gif
Aug 24, 2011 | 2002 Audi A4
How can I get it out of protect mode?
Protect mode indicates a short in the speaker wiring or a faulty speaker. Just disconnect speakers one at a time to determine which is the issue, then swap that speaker with a known good speaker from a different location (other side of car). If the headunit goes back in to protect mode when a known good speaker is connected, you know that the short is in the speaker wiring between the speaker and the deck. If the warning does not come back you know that the speaker is at fault, replace it. In most cases it is the speaker rather than the wiring. Good luck, should be an easy fix if you're familiar with car audio installation, if not, find a friend who will help you, it's not worth paying an audio shop $40 just to unplug your speaker.
Oct 08, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Memory card locked on a canonpowershot sx10is how to fix it will not let me in the format program
Take the card out and check to see if it has a switch, very small, that is in the locked position, this will stop you from formatting or even deleting things from the card
Jul 26, 2009 | Canon PowerShot SX10 IS Digital Camera
AVR65-"PROTECT" warning blinks upon Power On
open up the unit and change the buss fuses inside 2 small ones on the right side of receiver.
Dec 29, 2008 | Harman Kardon AVR 500 Receiver
Amp hook up
If you are referring to a warning light on a car, unless you knicked a wire that caused a warning light to come on. It shouldn't matter if you have an aftermarket amp. If you are referring to a warning light on the amp. Make sure that you are not under driving the impedence and not shorting any wires. If you dont have any shorts, then your amplifier is probably done for. Because you might have a short internally. Unless it is just in protect mode. I had a memphis amp that went into protect mode, I set it off to the side for a for a week or so and was bored so i hooked it back up and it worked. It still works and that was about 2 years ago. Good luck.
-Andrew Hawkins
Sep 02, 2008 | Car Audio & Video
"Overheating warning"
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 14, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Teac AG-D7900 Receiver Logo
22 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
